So this may have been asked before but I've googled like a madman and can't seem to find anything definitive. I just bought my 2600k+mobo. I'm working on oc'ing it. So some folks seem to use a fair amount of LLC and a bit of offset, while others nearly shut off LLC and use offset. I have two questions...which way is better? Secondly, right now, I'm trying LLC=Regular and offset=+0.080. When I'm in windows using prime95, the vcore gets to about 1.344-1.352 (once I saw 1.36, but never again). I'm pretty stable 4.6Ghz at this setting. My temps using primve for about 10 minutes hit around 70C. Can someone help me analyze these settings? I'd like to try to hit 4.7 totally stable if possible or more as long as the voltage isn't too crazy. I'm using a Corsair H60 mounted at the back of my case with the fan pulling...
<==airflow | case wall | fan | radiator | inside of case
