I've got a client with a new Dell R720 running 2008 R2 Standard with the Hyper-V Rolle installed running 3 VMs, an old 2003 R2 VM, an 2008 Flat 32bit VM and a 2008 R2 VM.
The 2003 R2 and the 2008 Flat VM were migrated from another box with the implementation of the new server. the 2008 R2 VM is a fresh install as a file server and was fine for approximately 3.5 months. Within the last month, the VM has dropped off the network (no traffic of any kind, in or out) randomly. The VM is still running and active, as I can connect to the console for live administration while the outage is occuring. A quick reboot of the VM solves the communication issue. Since this has happened multiple times, it's not a fluke.
To combat this, I have researched and found a few referenced hotfixes and installed them. All network offload functions have been disabled on all physical NICs, and I have tried another virtual network assigned to another physical NIC.
Got off the horn with MS Tech support earlier without a good feeling as the tech tried to turn on Jumbo Packets on a network not configured for them, but I did get an unpublished hotfix to install, so we'll see...
Any other ideas?
Any other ideas?
