IQUNIX ZX-1 Aluminum Mini-ITX Case. Build name: Green Machine 5.
SonDa5
SFF Build nick name: Green Machine 5.
CPU-Z validation base line bench.
CPU-Z Validation over clocked.
Hardware.
MB: MSI MPG B550I GAMING EDGE MAX WIFI AM4 AMD iTX Form Factor.
APU: AMD 5700G
MEMORY: Crucial Ballistix RGB 3200 MHz DDR4 DRAM Desktop Gaming Memory Kit 32GB (16GBx2) CL16 BL2K16G32C16U4RL (RED)
STORAGE: 1x Intel 670p Series M.2 2280 2TB PCI-Express 3.0 x4 QLC Internal Solid State Drive (SSD) SSDPEKNU020TZX1
PSU Corsair SF Series™ SF450 — 450 Watt 80 PLUS® Platinum Certified High Performance SFX PSU
CASE: QUNIX ZX-1 Aluminum Mini-ITX Case Smaller Air Cooling model with custom water cooling.
OS: W11P64B
H20 cooling gear: Alphacool
DC-LT 2 - 2600rpm + 40 DC-LT RESERVOIR
RADIATOR
NexXxoS UT60 Full Copper X-Flow 40mm +
WITH 3X Noctua NF-A4x20 PWM FANS (Hillman 127111 M3-.50 x20 screws fit perfectly with the fans and radiator).
CPU BLOCK NexXxoS XP³ Light - Acetal
Really cool build, impressive how you fit everything in there. How's cooling performance?
Thank you. I'm very satisfied with how it all came together and how it works. The AMD APU technology is in a great place right now and looks like it will be getting some great advances in the next couple of years.
This case with the radiator works out very well for this 5700g APU build.
Screen shots mid to high 30c idle temps on overclocked cpu and gpu and scored in the 1% group temps under 55c during the 3DMark DirectX12 test. Much better cooling than stock AMD heatsink.
