amazon seems to have this board at $99 after 20 rebate..is that a good deal for this board? ..is it worth it to buy a 1066 ram for this board?
http://www.amazon.com/gp/product/re...DKIKX0DER&s=electronics&qid=1245020627&sr=8-1
hole to hole distance 54.6mm and 59mm
oh... and grab the monitor application while there too... it reports the most accurate temps for the mobo (imho) once the latest drivers installed.Hey Folks,
I do have a problem, finding out my temperatures and fan speeds. I tried speed fan (only shows me core temp 1 & 2 and hdd temp). I tried other tools, but they either don't show anything or only very little information like speed fan. I tried to find something on the Internet and in this forum, but couldn't find anything. Can somebody help me?
After I performed the last BIOS update, I'm not able to control the MCP fan anymore. Did I do something wrong? Smartfan now works though.
My System:
Zotac 9300 itx-wifi
Intel Pentium Dual-Core E6300
2 GB RAM
ATI Radeon HD 4850
Sugo SG05
(Very proud of my system. First Computer I've ever "build" myself . Works so perfect and is nearly completely noiseless.)
Have you updated to the latest nvidia geForce 9300 chipset drivers? I am running Windows 7 (64 bit) and had same problem until I grabbed the latest (May 6th, v185.85 ) which then enabled the GPU temps etc..
iirc its under the GeForce/Ion grouping... but if you just google nvidia and go to the download drivers link... you can enter the GeForce 9 series as a choice and your OS version... eventually you will get to this driver set (and they should all come from the same 185.85 package so don't worry about which road you take to find it)
Thanks for your quick response.
I downloaded this driver http://www.nvidia.com/object/winxp_185.85_whql.html. While installing the installer tells me, that the nvidia setup programme can't find any driver that are compatible with the present hardware. Installation quits. Did I get the wrong driver?
I'm using Win XP Pro.
It's really a bit frustrating because everybody else gets informations about their fan speeds and temps ...
I don't get it. It shouldn't be that complicated to update the chipset driver ... you have any idea for my problem with the MCP fan control which is not existing in the "new BIOS" (04202009)?
Never mind, changing mem voltage does affect power consumption. I tested it with zalman mfc2....so I dare to suspect that this mobo doesn't REALLY change mem voltage
OC results anyone? Mine does embarassing 16.7% with e5200. PCB version is 01 (236-DA105-01J BF -> 4 phase cpu ps). Bios 0420. Stock voltage. 233,33 x 12.5 = 2917mhz (stock is 200x12.5). So 933 qfsb is the wall, 934 or higher won't boot no matter what (upping voltage, using mem divider, using only mem slot1/slot2, lowering cpu multiplier).
Memory I use: 2x2gb ocz platinum 1066 5-5-5 2.2V. I also tried 1x1gb ocz 800 4-4-4-15 and it didn't boot at 930 (didn't have motivation to look for max clock, 900 worked) 1:1 with 1.9v or 2.1v so I dare to suspect that this mobo doesn't REALLY change mem voltage (like cpu fan voltage on some pcb's like mine?). 800 cl4 spec'd 1gb stick should do 930 cl5 with 0.2v increase especially if it does 900 with "1.9v".
How did you get the bios settings to stick? Everytime I try to overclock it just fails. half the time I try to boot-up it will just run the fan's at full speed and display no video, then if you hit the reset it works fine.
I'm 99% sure this is just the BIOS... but any other thoughts... did you ever update your BIOS?
Thermaltake MeORB CLP0527 92mm CPU Cooler
CPU Temperature: 65 deg. C ... (<< stock cooler)
CPU Temperature: 27 deg. C ... (<< MeOrb)
I'm very much interested in buying the MeOrb ... would it be possible for you to post some nice pictures please ??
Thanks much !!
How do you disable C1E and EIST? i have disabled C1E (EIST i didnt find :/) but multipler and Vcore is still decreasing automatically. what is more, even when i set vcore +0,1 cpuz shows me still the same - 1,1875V @ x12,5 multipler and 1,15V @ x6 multipler. Because of that i cant OC my e5200 higher than 3.125 ghz - its last stable @ that f***ing unchangeable vcore....
Sorry about the delay, the first time I read your request it didn't "click".How do you disable C1E and EIST? i have disabled C1E (EIST i didnt find :/) but multipler and Vcore is still decreasing automatically. what is more, even when i set vcore +0,1 cpuz shows me still the same - 1,1875V @ x12,5 multipler and 1,15V @ x6 multipler. Because of that i cant OC my e5200 higher than 3.125 ghz - its last stable @ that f***ing unchangeable vcore....
