I can't find BIOS for this board on Zotac site anymore.
What gives ?
They pulled it back because it ruined some boards. A new one is in development, release supposedly this month.
What gives ?
is that the newest BIOS update with the fixes and such? I cant tell what version is from what date as its just a jumble of letters and numbers it seems. I am hesitant to try it though as i cant be sending it back for a new one if it doesnt work.
will pass on the information to our product manager and update everyone later.
I contacted Zotac on Twitter and directed them to this thread (the page where we ask for undervolting and thermal management).
My MCP temp swings between 32@idle and 44max@stress, i've changed thermal compound to arctic ceramique before I connected everything to my 9300-itx.
@Blazestorm
Can you register the board even if you bought it a couple of months ago already? Bought mine from Amazon.
Your Temps are quite low compared to my 65c, what case and set up are you using with your 9300 itx?
I already tried to apply Zalman Thermal grease but I still get the same temp.
My case right now is SG05 btw.
Gonna try making my own single CPU/NB waterblock, although I expect it to probably not work out well since I have no milling experince and getting my coper stock to make flat contact with both the CPU and NB will be tricky for me.. Still should be fun to try.
Ah CrimandEvil, ordered your PC-Q07 yet ?
I used the following:
zotac 9300 itx/wifi
I stuck a 40mm fan over my MCP but it only slightly made my temp better,now my idle is @ 63c & my load 66. I'm also wondering why my idle & load temp delta is too narrow. I might need a stronger 40mm fan since I barely feel any air from my current one.
Is the sink itself hot? If not, perhaps it needs to be reseated, possibly with better thermal 'grease'.
no undervolting options are possible, we are waiting for a bios that hopefully cointais this option. this mobo really needs this option, i tested the board with my quad X3219 B3, it only needs 1,0V but gets 1,25V. this makes a difference of 40W during load.... and thats for the much needed 12A rail on the psu.
I have problem booting with 2 memory sticks, is it a normal problem?
