Zotac 1080Ti Mini $430 shipped @ Ebay (Buy It Now) from Zotac
Status
Not open for further replies.
/dev/null
This should be way faster than 2060 super/2070 & is only +$30. Here is the Link.
Not a bad price if you can't wait for next gen. Also 11GB ram always attractive :)
I have one in both my linux box (1080p) and windows box (1440p) and they still run REALLY well.
Geezus
Good price on great performance. Just sold a 1080 ti and waiting for the 3000 series to come out to upgrade.
The Lurker
Might also be a good option for a plex server that needs hardware decoding
The Lurker
dviloria
I like the idea of this, particularly having an SG13 case, but I honestly have no first hand experience with this brand's products.
Question to the community: any concerns with quality issues from this manufacturer or this product in particular?
-thx
windianrecords
Hey I have a Zotac 1080 Mini that I've had since it came out, works great in an itx case, and the last three or so months it's been running almost 100% for Folding@Home for COVID - I've only had two other Zotac Cards and they've been fine!
kirbyrj
Wayyyy overkill. The cheap Quadro cards are best for that as they don't have stream limitations. Still solid deal. I rather wait for next gen to let's these fall even more
You can patch out stream limitations. But the 1080 is definitely overkill. I'd look at the revamped 1650 with GDDR6 personally for multiple stream Plex use.
mazeroth
Vengance_01
Even a 1660ti. Imo is overkill for a pure Plex server. The p400 is all you need for a decently sized server and multiple hw streams at once
kirbyrj
Can you go into details about the capabilities of the 1650 with GDDR6? I'm not finding anything on it for Plex decode/encode use, using Google and this spreadsheet:
https://developer.nvidia.com/video-encode-decode-gpu-support-matrix
Thanks!
It's the 1650 Super that I'm thinking of.
https://www.nvidia.com/en-us/geforce/graphics-cards/gtx-1650-super/
Override the 2 stream limit:
https://www.reddit.com/r/PleX/comments/9dim68/override_nvidas_2_stream_limitation_on_gtx_gpus/
The P400 also works.
mazeroth
Any reason to get a 1660 super or P400 over my current i3-9100 with UHD 630 graphics? I can decode/encode a ton of streams (have tested 5 h.264 at once without breaking a sweat; even threw an h.265 4k in there, for good measure).
Vengance_01
Nope. It's for us who run virtual Plex servers or older hardware that can't handle GPU decoding. I run mine using passthrough hardware to a windows 10 VM on a esxi 6.7 host.
The Lurker
Vengance_01
https://www.elpamsoft.com/?p=Plex-Hardware-Transcoding
This should help in tracking down the right gpu for use case.
Looks like the best bang for the buck. Only 50'ish bucks more than the p400.
Edit: no it isn't.
https://www.tomshardware.com/news/nvidia-geforce-gtx-1650-volta-nvenc,39161.html
You need to look at the 1050/1060 or 1660 of you want more juice than the p400/p620.
Edit 2:
https://www.evga.com/products/productlist.aspx?type=8
Perfect. 180 bucks for a 1060 that has it all.
Just depends on how many streams you need concurrently and this what you target. Remember you still have your CPU assist
kirbyrj
The Lurker
IIRC, the 1650 super has the Turing NVENC rather than the Volta one. That was one of the "hidden" benefits of the Super over the original.
Ooooooooh! Thanks for telling me.
edit:
https://www.microcenter.com/product...ed-single-fan-4gb-gddr6-pcie-30-graphics-card
I think this is perfect. Best of all its small.
Found this in the fine print of the specs link on this page: https://www.nvidia.com/en-us/geforce/graphics-cards/gtx-1650/
TU117 GPUs have Volta encoder, TU106/TU116 GPUs have Turing encoder. Check with manufacturer for exact model.
and in th
odditory
Correct. Which also means you can use SVP4 (SmoothVideo Project) and enable Nvidia Optical Flow acceleration. https://www.svp-team.com/
I got this cute Zotac 1650 Super and its been a godsend for HTPC duties, as well as a great fallback card for my main rig when I'm between flagship cards. https://www.amazon.com/gp/product/B07ZKSZ5LF/
The Lurker
Well I am glad I went down this rabbit hole with you guys.
I had to upgrade my machine to server 2019 to use the newest nvidia driver and patched it to unlock the stream limit but the result is absolutely worth it. I wish I knew about this sooner but as they say ignorance is bliss. This machine hosts plex, a Seafile VM and also blue iris with 4 1080p cameras. With the cameras now decoding on the video card and a plex transcode now on the card the whole system just feels so snappy. I have never seen plex load so fast while seeking during a transcoded playback.
I can see how vram could be a limit though. 4 cameras consume 1gb of vram. Add a plex stream and its another 200 megs. With just the cameras GPU utilization is 18%. Add a plex transcode from X265 and its 26%. Basically nothing.
I am very very very happy right now.
Status
