I intend on installing a ZEROtherm BTF90 92mm Silent UFO CPU Cooler on a IP35 Pro MB in a CM 690 case, with two 140mm fans installed as exhaust in the top.
I will have an 140MM fan installed on the bottom, a 120 MM in the front and two 120 MM fans on side panel, all as intakes.
My question is would it be better to face the BT cooler fan exhaust to the rear towards(120MM) exhaust fan or towards the 2 top fans.
