Im ordering a rig from monarch (they put it together) and I was wondering what hsf to get on the opoty 165. They offer the zalman cnps7000b alcu available to ship on the rig already installed. I want to get the best oc (obviously ) and I wanted to know if this hsf is up to par. Also, they offer the Shin-Etsu g675 compound for $15. Many people have told me to just get the $13 hsf they offer and install the scythe ninja or equivalent myself (the 165 is oem). The thing is, if I do get the scythe ninja or the tt big typhoon aftermarket, Im kind of worried because I dont how to install the hsf at all. Well, I have an idea , but Ive never done anything like that myself because Ive always been a lappy time. Taking out the mobo, unconnecting everything to it makes me nervous (i will have to do this, right). I asked the monarch rep if installing a hsf myself would void my warranty and the answer was, no it wouldnt but Id have to pay the $75 shipping both ways if I did mess anything up.
So, what do you think is the best option? Just say screw it and get the zalman? Generally speaking, what kind of an oc would i loose by using this hsf? Also, is it worth getting that g675 compound?
What do you think?
Thanks,
jcll2002
BTW, if you scroll down to heat sink, the options they have available to ship installed on the rig are listed. http://www.monarchcomputer.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=M&Product_Code=80311
BTW, dont try to convince me too build it myself
What do you think?
Thanks,
jcll2002
