entermymatrix03
- Mar 8, 2005
hey guys, i have a small problem. i installed my new mobo (Gigabyte K8N-939) yesterday. i have my zalman cpu heatsink on my amd athlon64 4000+. in order to install this heatsink, you have to remove the normal mounting hardware from the mobo and use the zalman backplate for support. my computer will boot windows once or twice and then load windows and restart. sometimes my monitor doesn't even come on and my power light will come on and the fans will spin and then restart without even showing the boot up screen. do you guys think maybe i am grounding out the mobo? the screws that hold the zalman in place are metal. what do you all think? i am not using the cardboard washers with the mobo because i lost them. i am using notebook paper reinforcers. the little paper sticker ones. are these not thick enough?
also, can i just mount the zalman using the original mounting bracket? it sits a little higher than the copper screws zalman provides. has anyone else done this instead?
