Zalman FC-ZV9 Fatality and new cards?
evaseeker
hi i want to know if the old Zalman FC-ZV9 Fatality is compatible with newer cards like ati's 4850 and 4870.
thanks.
It's basically a VF900, so yes, it will work. However, it will not do to well with the increased heat output of these newer cards. I recommend you either stick with the stock cooling (especially with a 4870) or go with a newer cooler like the Arctic Cooling Accelero S1 Rev. 2 instead, if you're dealing with a 4850.
