Take a look at this: http://www.newegg.com/Product/Product.aspx?Item=N82E16835233029What brands are recommended for the i7, aside from the stock HSF for non-overclockers?
The 9900 is $75, so it wouldn't be saving money.but if you want to save cash i'd say a zalman 9900 is a good idea
I wouldn't. My CNPS9500 barely handles the heat of my q6600 @ 3.2ghz.
Do you have hyperthreading enabled and are you using prime95 with more than 1 thread. This temp seems very unlikely if you were running it with all four threads. It might help if you posted a Core Temp or RealTemp screenshot of this while priming with four threads.Well surprisingly my 9500 is holding up great.
With 2 hours of prime going.
Its at 3.6Ghz its averaged a temperature of 72.6c
