BigDaddy85
- May 13, 2005
mmm i am lendin toward cnps9500 instead of 7000 one.
chrisyak said:I was checking out a forum and a guy said a rep told him that the CNPS9500 would not be out till October.
So i thought i might contact Zalman myself to get the story straight and i ended up checking out their forum where a the Administrator of the forum a Zamlan USA Technical Support Employee answered a question about the release saying " The product will be available in October.".
October come on.........
Some stores are saying end of aug,others septand Zalman forum Oct....gessh...........
J3RK said:My CNPS7700-Cu is working quite well. My Venice at 2500 is running at 33C. If that isn't working well for air, then I'm not quite sure what would be. That temp is a few degrees below a friend's identical setup with an XP90.
Pre Orders Only! This item will begin shipping on September 19th on a first come first serve basis.
do you see any difference in chipset temps?snoops said:Got mine from sharka two days ago. It replaced a XP-120. So far idle is exactly the same, load is 2 deg cooler. It is however way more quiet than the fan I had on the XP-120 even at max rpms. IMO if you have a XP-90 or XP-120 don't bother unless you have money burning a hole in your wallet.
snoops said:BTW I know the fucking thing is crooked, I mounted it like that on purpose because the fan is blowing straight down and it was also making a humming sound when i had it straight.
SLiCkFX said:Well, did you know it's not supposed to be blowing straight down?
You have it mounted totally wrong. The fan should be in the same orientation as your rear case fan or else the hot air is just going to be bouncing back at the heatsink. I would read page 3 of your manual again .
what kind of temp difference did you see?fallguy said:This week I installed a NV Silencer rev.3 on my GTX, and now this. $100+ on cooling... but I wanted hot air out of my case.
EnderW said:nice pics Bassist-X
how's the noise at 12V?
and excaliberpc has it for $64.95 free shipping
http://www.excaliberpc.com/Zalman_CNPS9500-LED_Silent_Pure/CNPS9500-LED/partinfo-id-556646.html
