Cool, I'd go XP-90 then.Glow said:Socket 939 what would you guys go for?
The heatsink comes with these clips that hold the fan on to the heatsink. You can see it here: http://systemcooling.com/thermalright_xp-90c-01.htmlHow does the fan attach to the XP-90?
If you want the cooler to be quiet at "stock" then go with the L1B but if don't mind alittle noise then go with the M1, I would get the M1 and use something like Speedfan to control it's speed just in case your CPU is running alittle hot you can run the fan at a higher speed to help cool it down faster.Glow said:is the L1b 92mm fan better than the Panaflo M1?
Im trying to setup a very quiet but overclocked to 2.6 venice, which would be the recomendation then? I have plenty of fans and would be using my fanbus either way. Im using a 7000AlCu now on the 2.6C (IIRC) but dont have the A64 mounting stuff, so thats out unless I could grab some from somebody else. Oh, by quiet I mean I run the 7000AlCu between 5 and 7v 90% of the time.CrimandEvil said:Cool, I'd go XP-90 then.
Or possibly one of those Coolermaster AquaGate minis, they're suppose to be really restrictive.ryuji said:you know what.. i bet they used the thermaltake bigwater for comparison
i thought the aquagate was supposed to be one of the best bay water cooling kitsCrimandEvil said:Or possibly one of those Coolermaster AquaGate minis, they're suppose to be really restrictive.
