Zalman CNPS7000A Will it fit a Ic7
confuzedaznboi
I am planning to buy the Abit Ic7 mobo and putting the Zalman CNPS7000A on it. I heard from somewhere it doesnt fit on the motherboard is this true? Also I am planning to buy the Aspire X Dreamer II is there enough space to fit this hsf in the case and will i need to support the zalman to prevent too much weight going on my motherboard thank you.
The heatsink fits fine I have one on my IC7 and it is quiet and cool.
Should fit on fine, at the zalman website there is a list of boards with compatibility issues so you can double check. The case should be fine too.
