Zalman CNPS 7000AlCu and P4P800
NeoNemesis
Anyone know if this heatsink is compatible with the P4P800 mobo?
oops, i posted in the wrong section, sorry about that.
spicey
I haven't tried it.It's not on the list of incompatible mobos on the website, so I guess it will install
DieLate
For what it's worth, it fits with plenty of room to spare on my P4C800-E. I would think the setup around the CPU socket on both boards should be fairly similar.
dagamore
IIRC the p4p has the cpu socket up a little higher then the p4c, but if you have some room over your MB and the psu it should fit fine, i know in one case i had to remove the fan gard on the PSU for it to fit, it misses the fan, but the fan gard was in the way. but most of the other cases i use are an inch or so taller and have the room between the psu and the mb, so ti all works out fine.
