So I just bought 2 Zalman-2HC2 hdd coolers for a case mod thats all acrylic and these coolers have wire for grounding the hard drive since they will almost be isolated from the case to aid in noise prevention.
I just wanted to be sure that I would be safe in leading the ground, that would normally be connected to a steel/aluminum case, to one of the motherboard standoffs. If not, could I connect it to the casing of the psu?
-Thank You.
-Thank You.
