night_2004
- May 31, 2007
Quick question about the Z68 chipset here. In all the previous boards I have had Intel always makes it possible to set up and monitor RAID arrays in BIOS without the need for the Intel RST or MSM programs.
Is it possible to set up an SSD cache from the same pre-boot environment?
Because from what I can tell you have to have the 10.5 drivers installed in Windows to set this up in the OS, but the 10.5 driver is a pile of cow dung that is responsible for every system lockup I've experienced on two different Sandy Bridge chipsets.
I would try it myself, except I don't want to dish out the cache for a good Intel SSD without knowing that I can use it and not have lock ups.
Update to Question
Poking around a little bit tonight and I noticed there is a menu item in the Intel boot interface listed "Acceleration Options" that somehow I missed before. It sounds like that would be for the Z68 SSD caching but can anyone confirm you can set up a cache in through that menu item? I'm apparently not allowed to do anything with that item since I apparently don't have an SSD attached to the computer (further enforcing my thought that perhaps that is indeed what I am looking for).
Update to Question
