SomeGuy133
- Apr 12, 2015
and you are taking my words out of context and using red herrings by talking about products i never mention. I explicitly stated 2 boards and you keep using a red herring about low end boards.Yes, those are my words and I stand by them. Unfortunately, you are taking them out of context. It was a good motherboard but I still wouldn't put it's quality on par with most of what ASUS, MSI and GIGABYTE offer. Again, you used the word "best" and no motherboard from ASRock I've ever seen would qualify as the "best" in my experience for one reason or another.
ASUS supports XEON CPUs, ECC etc. on some models. That's not the feature set I'm talking about. That's not the feature set that costs money to implement either. I'm talking about audio, SATA ports, USB controllers, overclocking features, voltage check points, etc. You can't tell me that a $250 ASRock board is as feature rich as a $500 ASUS motherboard because it isn't. Even if it was, the quality wouldn't be on the same level.
Specificially, the X99-WS was a fantastic motherboard with the minor problem of the UEFI BIOS settings not being set to what they should be by default for stock operation in our case. That doesn't mean that this is the "best" X99 motherboard out there or a better option than those offered by the competition. It's a good motherboard at a good price but as usual, ASRock doesn't really compete until you get into their more expensive options.
You claimed flimsy in your post and i retorted by showing your published review states 100% to the opposite. You are double talking.
You also said one of the best, which is a range which i followed same term-age. The ASRock x99 WS and OC formula competes with the best and is a fraction of the price and that is a fact. You keep using red herrings to distract from that.
you claimed i stated best which i didn't. I stated one of the best....jeez.
