I have these Z-5500 and while playing no sounds no matter if the volume is high or low there is this like static sound on the back which i've heard before from other audio devices, it's low but noticeable if you are silent. If you put the volume higher you can hear it higher, it's like a "shhhhhhhhh" sound. It only goes away if you turn off the speakers. Is this normal?
