It is more than enough.can that 300w even power that card?
It won't physically fit in the case...HD4850 is the best card you can put in there.Only problem that won't allow a 4870 in there is that lame PSU and 4870's 2 6 pin. AHH!
wuts the 12v+ rated to?
Great news. Then I have no choice but to wait for the SG06 instead. I'm hoping for a a stronger PSU with 2 6pins.
I dunno why it's so hard for people to grasp - You want tiny and restrictions, go ITX. You want more flexibility and ATX-like hardware, go mATX. All the complaining about how you can't have your future sci-fi dream computers right now is very Zzzz. mATX is restrictive, ITX takes that even further, nothing new.
Yea well that's not happening right now is it? I think you're in the wrong time.
Ok but the Thermalright could be too high, no? I mean the fan would be directly front of the PSU, which is fanless I guess?
I was thinking of the Scythe Shuriken, but I saw on other forums that it wasn't efficient.
I finally got my cables routed and the new heatsink mounted. As i suspected, the clearance silverstone states of 78mm is quite conservative. I mounted the heatsink (62mm w/o fan) and a yate loon 120x20mm fan and it just fits under the power supply. There appears to be a 1mm gap between the 3.5 hdd cage and the fan. The power supply appears to have a clearnce of +1mm more than the hdd cage (2mm total). It is as tight as i feel comfortable to mount a heatsink.
Snip
So in conclusion 62mm+20mm= 82mm looks to be the max height for a heatsink fan combo if you plan on using a 3.5" hdd. If not, you might squeeze another mm or two but unless you either go with a pico psu or don't mind having you heatsink fan combo touching the power supply that's it. I hope my observations have been helpful and i should be able to get some pics later.
I like the Scythe, but the damn 775 push-pin mounting just about kills it for me. It's hard to be confident that the thing is on there to stay.
JonDoms,
can you fit 2x 3.5" HDs in the Sugo 05?
considering this for a WHS build.
Thanks!
Not if it's for Lanning. Those pins pop out more oftne than you think. I really hate the push pin design but what choice do we have for low profile? Any bracket system out there that are not huge? I have a Zalman 8700I might try out but that thing is huge.Push pins are fine... Geez, stock heatsink is used far more than you'd think.
Zip tiesNot if it's for Lanning. Those pins pop out more oftne than you think. I really hate the push pin design but what choice do we have for low profile? Any bracket system out there that are not huge? I have a Zalman 8700I might try out but that thing is huge.
What is the PSU model bundled with that case? Does it have a fan?
If possible, can someone post a picture of the PSU sticker?
Thanks
