Hi!
My first post on the [H] forums, so go easy on me
I'm planning on building an All-In-One and would like to hear your comments on hardware setup and configuration. Here we go!
Vision
A fairly powerful virtualising server with tons of disk space for personal (family and friends) use.
Aim
A quiet ATX case, with room for at least 6 storage drives (+ 2 for VM storage), server grade motherboard, Xeon quad core and 32GB ECC RAM.
Build
Configuration
Crash plan
If I want to upgrade ESXi, I'll make a backup to another USB key first.
If the ESXi setup totally blows up for another reason and takes the FreeNAS VM with it, I have a backup on a USB key that I have previously tested.
I have yet to figure out how to backup the other VM:s though. Maybe backing up to the NAS would be okay...
Finally
So, what do you think? Does this sound like a good setup?
What about the migration from my current setup (Debian box running zfs-on-linux)? Seems safe?
Vision
Aim
Build
- Motherboard: Supermicro X10SL7-F
I'm thinking server grade Haswell here. This board have become very popular as it sports dual Intel I210-AT NICs and the LSI 2308 SAS controller. - CPU: Intel Xeon E3-1230v3
No competition price/performance wise. - Storage Controller: IBM ServeRAID M1015
This seems to be THE controller to get. The NAS storage goes here. - RAM: Kingston ValueRAM DDR3 PC12800/1600MHz CL11 ECC 32GB (KVR16E11K4/32)
Do I have to go 4x8GB or can the above mentioned motherboard handle 16GB sticks? What about chip compatibility? I'm kind of struggling with finding what RAM are compatible... - Storage (HyperV): Kingston DataTraveler 100 G3 8GB
ESXi goes here. - Storage (HyperV backup before upgrade): Kingston DataTraveler 100 G3 8GB
Clone ESXi to this one before attempting an upgrade. - Storage (Fallback FreeNAS): Kingston DataTraveler 100 G3 8GB
A fallback FreeNAS that's installed first and thoroughly tested. Can later be used if for some reason the ESXi installation goes bonkers - Storage (VM:s and snaps): 2x 500GB SATA HDD
Use on-chip LSI 2308 RAID-1 for these and store VM:s and possibly snapshots on them. - Storage (Pool): 5x WD Green 2TB
I have these in a RAID-Z configuration on my current server. Will in time upgrade to a larger RAID-Z2 or something - Enclosure: Fractal Design Define R4
Reasonably priced and fairly quiet. Takes 8 (+3) drives which allows room for upgrades - PSU: Seasonic G-450 450W
Can't go wrong with Seasonic
Configuration
- Make sure the 2308 is flashed to IR mode and configure a mirror on the 2x500GB drives.
- Make sure the M1015 is flashed to IT mode.
- Export the zpools on my old setup.
- Install FreeNAS on one of the USB keys, import the zpools and make sure the storage is working as intended.
- Export the zpools again.
- Install ESXi on another USB key (in the onboard USB port!)
- Install FreeNAS as a VM and import the zpools here (last time!)
- Share the datasets with other clients using iSCSI or NFS (I have to read up on this)
Crash plan
Finally
