best [486]
- Aug 28, 2005
I got the PSU all fitting with a beefy fan and all...
Fan and unmodded power supply [amperage rating sticker moved to side from top]
Fan on PSU, 1st revision
NT-07 with fan and shroud removed.
NT-07 without fan and shroud is level with the northbridge heatsink.
Fan was too thick by 2mm, so I cut off the mounting points on the intake side, so I could mount the exhaust flange inside the PSU's case [it only barely had room in there for it...] Also had to trim the 60mm fan a little bit for clearance, it's the quietest 60mm fan I've heard, so it's staying in, it's gotta be better than no fan there...
PSU all assembled...
[Sorry for blurry pic...] It barely fits!, the CPU'll get enough air, I'll say!
