yate loon or stock fan for H50
ironforge
I have several yate loon d12sl-12 fans from jabtech. I also have two of the stock 120mm fans that come with corsair H50's.
Would it be better to use 2x corsair fans or 2x yate loon fans for my corsair H50. Will mount in a corsair 800D case in push/pull configuration.
hdnut
If you already have both set of fans, why not test it out yourself? It's simple as just swapping them out and monitoring the temps as you stress the CPU...
hcc_tech
this would be nice. you dont even have to unmount the cooler to do it. please share your results.
W.Feather
[H]ard DCOTM x4
IIRC from my use of the fans on my H50's .... the Yates will be louder, and i think have slightly better performance (but i only used one of the stock fans, and for a short period of time at that...so i'm grasping at straws to remember)
