jbltecnicspro
- Aug 18, 2006
Good evening all,
I just wanted to make those of you who want a PCI soundcard that can run in DOS aware of this sound card. The YMF-724 is just a two-channel sound card, but it's pretty much the ultimate PCI legacy sound card. It has a real OPL3 chip, so that your Sound Blaster or Adlib titles will play just nice with it. It emulates the Sound Blaster Pro digital part just fine as well. I have a gameport to MIDI cable adapter on its way from Ebay, so we'll see just how the MPU-401 compatibility holds up. Early trials with none of my sound modules hooked up to games known to throw a fit if they don't find a legitimate Roland MPU-401 device seemed to have passed, and I haven't gotten any errors yet. I'll finalize my findings once I actually get my MT-32 and Sound Canvas hooked up to it though. I'm about to hit the bed right now, but if you all want, I can post links to the DOS drivers for this guy, and explain the process of getting it to work in DOS.
The cards usually go for pretty cheap. I paid $10 shipped for mine. The one huge caveat though, is that it requires a motherboard with Distributed DMA. There's a thread on VOGONS as to which motherboards support it. But if you don't have it, your SOL. Usually DOS and PCI is a bad combination (so I've read), so I decided I'd throw a heads up to anyone wanting to take a crack at a DOS box that doesn't have an ISA slot. Geniune Intel boards seem to be your best bet (I have an old Celeron 1.7 Ghz Socket 478 that's Intel-branded, and the card works perfectly). More to come! Good night.
