MrWizard6600
- Jan 15, 2006
firstly, think I can I start an acronym: Yet Another Build Request (YABR)? It would follow in the long line of FLOSS "Yet-Another" acronyms.
Anyways, to follow the template:
General purpose. Diablo III is as extensive as it gets.
$1100 after tax and (if any) shipping.
Vancouver BC Canada → No shipping on NCIX parts.
CPU, Board, RAM, Optical & Hard drives (would like to squeeze a 128GB SSD in), Case.
Keyboard, Monitor.
That should be everything except for a graphics card and a mouse.
I'm using an re-using an old GTS 450 and a mouse. I was surprised to learn that the GTS 450's contemporary appears to be the GTX 750's, which are about $100. Given that and the fact that all we need out of this build is to play Diablo 3, I'll stick with the GTS 450.
6) Will you be overclocking?
If you can convince me that overclocking is not a bad idea inside the cooling envelope of a default cooler, sure, but otherwise, probably not. I'd like to avoid aftermarket cooling.
Well you guys pick it, but I'm expecting something upward of 1080p
ASAHP, I'd like it to be built (with room for any defective-part-swapping) in 1 week.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
all of these are flexible, but ideally
Yeah, an MSDN provided Windows 8.1 x64
A couple notes:
Cheers, and thanks for any help!
-Geoff
Keyboard, Monitor.
- As there will likely be a graphics card upgrade in a year or 2, a full PCIE 3.0 x16 slot
- mATX
- 4+ USB 3.0
- Not going to have a lot of drives, 6 SATA ports will be more than enough.
A couple notes:
- Regarding this blog post, I'd really like to avoid Seagate and even WD. But because of Hitachi's general lack of availability in NCIX, I suppose I'll go with Western digital. I'm happy to pay $40 on top of the usual $80/TB to bump myself up to one of the higher grade drives if there's any kind of MTBF increase.
- Along the same lines, I'd like to stick to conservative parts. I'd like to use boards with known-good BIOS's from Asus and Gigabyte (or preferably Intel although as I understand it they're out of that business), and PSU's built by CWT or Seasonic.
-Geoff
