Finally lapped my Thermalright Ultra120 Extreme. The heatsink base was extremely CONVEX!
The lapping work took me more than 6 hours. Used 320x2, 400x2, 600x2, 1000, 1500 and 2000grid wet/dry 3M sandpapers. (more details and pics on this in the air cooled forum
Idle state after the system finished the Vista performance rating bench.
Prime small fft stress test full load all 4 cores.
NOTICE: I'm using Vista 64bit OS. So I can only open Speedfan 4.32 to get the core temp.
Coretemp 0.94/95 and Intel TAT aren't supported in Vista x64.
Before you start flaming about Speedfan's core temp inaccuracy, know that Speefan 4.32 assumes the max Tjunction is 85c instead of the actual 100c from the Quad.
You've to ADD +15c on top of Idle/Load temps to get the actual core temps. And it's still an incredibly low temps for a high-end air cooled quad at stock settings.
*Maybe my lapped job did the trick
I've also posted the temp readings from BIOS and Asus AI suite as a reference. Those temp are always lower than the actual core temp.
So after you've added +15c on top of the core temp reported from Speedfan 4.32, the core temp is accurate and does get higher than the temp reported from Asus AI Suite and BIOS.
Here's is another reference temp reading/OC from my previous setup before I just swapped to the G0 Q6600 last night.
This is just to show you that Speedfan 4.32 is actually picking up the core temp accurately given that C2D has Tjunction of 85c instead of 100c from the quad.
