I'm working on a friend's PC, and I'll admit this problem's got me stumped. It's a Dell P4 1.7 Ghz, XP Home with 128 MB ram. When they brought it to me, it wouldn't boot - complained about missing files. They told me the machine had frozen while installing a Windows update, so they had killed the power. I ended up using their XP install CD to do an OS repair, and this has gotten Windows working, but with no virtual memory. I get the following error message:
Limited Virtual Memory
Your system has no paging file, or the paging file is too small.
To fix this problem, go to System in Control Panel, click on the Advanced tab, and under Performance, click Settings. On the Advanced tab, click Change. Click 'Custom Size' and then type an initial or maximum paging file size.
The problem is that Windows refuses to apply any changes I attempt. It shows a current pagefile size of 0. I try setting the initial and max to 384, click "Set" and nothing changes. I have tried disabling virtual memory, restarting, re-enabling it, restarting -- still nothing. I have tried system managed, still no luck. "Currently Allocated" always shows 0 and pagefile.sys is nowhere to be found.
I did some searching with Google and in the MS Knowlegebase, and found this: http://support.microsoft.com/default.aspx?scid=kb;EN-US;Q315270 Basicly, this problem can happen when the System account or Administrators group loses access rights to the c: drive, so the pagefile can't be created. I did check effective rights and both System and Administrators had full rights to c: I did try manually specifying full rights for both, and I even tried enabling full rights for the Everyone group, without any success.
I also tried the fix here: http://support.microsoft.com/kb/257758/EN-US/ even though it lists just NT and 2000 as affected. No help there either.
Geez... you thought running XP on 128 MB was bad, just try it without virtual memory. I get "Out of memory" errors just trying to open the device manager. Does anyone have an idea how to fix this? I'll give the [H]ard folks a few days before I start backing stuff up for the wipe and re-install.
Thanks
Thanks
