- Apr 10, 2003
XPG Spectrix D40 RGB DDR4 3200MHz 16GB (2x8GB) 288-Pin PC4-19200 Desktop U-DIMM Memory Dual Retail Kit (AX4U320038G16-DRS) is $87.25 after you click the $10 off coupon under the price. 4 hours 30 minutes left on the deal! It is ADATA memory.
https://www.amazon.com/dp/B0749T64BS/
Amazon!
According to NewEgg
https://www.newegg.com/Product/Product.aspx?Item=N82E16820215175
Amazon!
According to NewEgg
- DDR4 3200 (PC4 25600)
- Timing 16-18-18
- CAS Latency 16
- Voltage 1.35V
