Well I got a few new riggs for some basic computing needs and low entry gaming but I want to max out the performance. So in terms of the OS should I use xp, vista or 7?
As you can tell it's nothing mind blowing, grandfathering down some video cards from some other pcs. My 1st inclination is to go with Windows XP 64bit, though I am having trouble getting SSFIV:AE running on it.
- Sony Optiarc CD/DVD Burner Black SATA Model AD-7260S-0B - OEM
- AMD Athlon II X3 445 Rana 3.1GHz Socket AM3 95W Triple-Core Desktop Processor ADX445WFGMBOX
- G.SKILL Value 4GB 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL9S-4GBNT
- GIGABYTE GA-M68MT-S2P AM3 NVIDIA GeForce 7025/nForce 630a chipset Micro ATX AMD Motherboard
- Seagate Barracuda ST500DM002 500GB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard
