I have been having some network issues with laptops on our lan. In certain instances laptops will be docked but still attempt to use the wireless connection to login etc even when a wired connection is available.
What makes this worse is wireless will sometimes connect to a non-work/supported wireless and the client will not be able to login, never mind the performance drop...
Doing some research I figure I only have 2 options.
1. Have users disable wireless (ummm these are users we are talking about, the higher the pay grade the greater the trouble... our CIO is the worst, insisting her itunes is for business yet we don't support any apple products)... All this music magically appeared on my work laptop... it was magic cause it was apple lol.
2. Manually configure the LAN nic Metric.
As per http://support.microsoft.com/kb/894564. Doing "cmd.exe route print" commands I have found that sometimes the wireless and lan interface receive the same metric (20 = 20Mbps to 200Mbps) if automatically assigned by XP. This makes sense given the glitches we see.
So this looks like our solution, either force LAN nics to use a lower metric or force wireless nics to use a higher metric.
I have been testing forcing LAN to metric of 10. Seems to work pretty good, if the lan is disconnected the metrics drops... If plugged in, the metrics reappear and the traffic switches over OK both ways.
Has anyone done this, or foresee any problems with mannually setting the LAN metric to 10?
