We have had 29 machines dead this morning after an SMS push of SP2. here is the scvpack.log file. any ideas on what could be causing this?
[svcpack.log]
6.259: ================================================================================
6.259: 2006/04/10 19:02:36.858 (local)
6.289: \\SACMGTSMS001\SMS_WKS_DIST$\SMSPKG\RC10001C\update\update.exe (version 5.5.1005.0)
6.299: Service Pack started with following command line: /passive /o /n /norestart
6.550: Return Value From OnACPower = 1
6.550: OnACPower returned value( 0x1 ) which is Equal To 0x1
6.550: Condition succeeded for section OnACPower.Section in Line 1 of PreRequisite
6.550: SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\WindowsFeatures is not Present
6.550: First Condition in A6Block.Section Succeeded
6.550: Condition succeeded for section A6Block.Section in Line 2 of PreRequisite
30.394: DoInstallation: CleanPFR failed: 0x2
30.424: SetProductTypes: InfProductBuildType=BuildType.Sel
30.434: SetAltOsLoaderPath: No section uses DirId 65701; done.
31.125: IncludeDirectoryIdFromInfSection: No DirId found for: DontRemoveOnUninst.DirId
31.135: DoInstallation: FetchSourceURL for \\sacmgtsms001\sms_wks_dist$\smspkg\rc10001c\update\update.inf failed
31.135: CreateUninstall = 0,Directory = C:\WINDOWS\$NtServicePackUninstall$
35.361: Conditional load of section MSN.Block.Condition succeeded
35.361: CheckRegistryValue: RegOpenKeyEx for SOFTWARE\Microsoft\Active Setup\Installed Components\{FDC11A6F-17D1-48f9-9EA3-9051954BAA24} KeyName failed :0x2
35.361: Conditional load of section WindowsMessenger.Condition succeeded
45.656: BuildCabinetManifest: update.url absent
45.666: Starting AnalyzeComponents
45.676: AnalyzePhaseZero used 10 ticks
45.816: No \\SACMGTSMS001\SMS_WKS_DIST$\SMSPKG\RC10001C\update\updtblk.inf file.
45.816: User specified '-o'; ignoring any OEM driver files.
87.045: AnalyzePhaseOne: used 41369 ticks
87.055: AnalyzeComponents: Hotpatch analysis disabled; skipping.
87.055: AnalyzeComponents: Hotpatching is disabled.
87.055: FindFirstFile c:\windows\$hf_mig$\*.*
108.927: AnalyzePhaseTwo used 21842 ticks
108.927: AnalyzePhaseThree used 0 ticks
108.927: AnalyzePhaseFive used 0 ticks
116.237: AnalyzePhaseSix used 7310 ticks
117.760: AnalyzeComponents used 72094 ticks
117.760: Downloading 0 files
117.760: bPatchMode = FALSE
117.770: Inventory complete: ReturnStatus=0, 86635 ticks
117.770: Num Ticks for invent : 86635
117.810: Conditional load of section WM.Reg.Install.Condition succeeded
117.810: CheckRegistryValue: RegOpenKeyEx for SOFTWARE\Microsoft\Active Setup\Installed Components\{FDC11A6F-17D1-48f9-9EA3-9051954BAA24} KeyName failed :0x2
117.810: Conditional load of section RPCProtseq.Reg.Install.Condition succeeded
117.810: Conditional load of section Msdvbnp.Reg.Install.Condition succeeded
117.810: Conditional load of section Psisdecd.Reg.Install.Condition succeeded
117.810: Conditional load of section Mpeg2Data.Reg.Install.Condition succeeded
117.810: Allocation size of drive C: is 4096 bytes, free space = 76173848576 bytes
140.442: Drive C: free 72645MB req: 251MB w/uninstall 0MB
140.442: CabinetBuild complete
140.442: Num Ticks for Cabinet build : 22672
142.595: Starting process: \\sacmgtsms001\sms_wks_dist$\smspkg\rc10001c\\update\fixccs.exe
143.627: Return Code = 0
143.627: Starting process: \\sacmgtsms001\sms_wks_dist$\smspkg\rc10001c\\update\nv4prep.exe
143.977: Return Code = 0
143.977: Starting process: \\sacmgtsms001\sms_wks_dist$\smspkg\rc10001c\\root\cmpnents\mediactr\i386\MCPreIns.exe \\sacmgtsms001\sms_wks_dist$\smspkg\rc10001c\\root\cmpnents\mediactr\i386\ \\sacmgtsms001\sms_wks_dist$\smspkg\rc10001c\\ip\ \\sacmgtsms001\sms_wks_dist$\smspkg\rc10001c\\
144.688: Return Code = 0
144.688: Starting process: C:\WINDOWS\system32\rundll32.exe C:\WINDOWS\system32\apphelp.dll,ShimFlushCache
144.738: Return Code = 0
144.738: Starting process: \\sacmgtsms001\sms_wks_dist$\smspkg\rc10001c\\update\spnpinst.exe /snapshot
145.089: Return Code = 0
145.089: Registering Uninstall Program for -> Windows XP Service Pack, Service Pack 2 , 0x0
155.183: Conditional load of section MSN.Block.Condition succeeded
155.183: CheckRegistryValue: RegOpenKeyEx for SOFTWARE\Microsoft\Active Setup\Installed Components\{FDC11A6F-17D1-48f9-9EA3-9051954BAA24} KeyName failed :0x2
155.203: Conditional load of section WindowsMessenger.Condition succeeded
155.324: UpdateMonitoredListFailed WithError 0x6ba
156.625: PFE2: Per File Exceptions will not be used.
158.869: GetCatVersion: Failed to retrieve version information from C:\WINDOWS\System32\CatRoot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\wmerrenu.cat with error 0x57
158.869: GetCatVersion: Failed to retrieve version information from C:\WINDOWS\wmerrenu.cat with error 0x80092004
159.279: GetCatVersion: Failed to retrieve version information from C:\WINDOWS\System32\CatRoot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Tmp.0.ntprint.cat with error 0x57
159.319: GetCatVersion: Failed to retrieve version information from C:\WINDOWS\Tmp.0.ntprint.cat with error 0x80092004
161.152: GetCatVersion: Failed to retrieve version information from C:\WINDOWS\System32\CatRoot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Tmp.0.nt5.cat with error 0x57
161.232: GetCatVersion: Failed to retrieve version information from C:\WINDOWS\Tmp.0.nt5.cat with error 0x80092004
166.550: GetCatVersion: Failed to retrieve version information from C:\WINDOWS\System32\CatRoot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Tmp.0.mstsweb.cat with error 0x57
166.550: GetCatVersion: Failed to retrieve version information from C:\WINDOWS\Tmp.0.mstsweb.cat with error 0x80092004
166.680: GetCatVersion: Failed to retrieve version information from C:\WINDOWS\System32\CatRoot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\msn9.cat with error 0x57
166.680: GetCatVersion: Failed to retrieve version information from C:\WINDOWS\msn9.cat with error 0x80092004
166.840: GetCatVersion: Failed to retrieve version information from C:\WINDOWS\System32\CatRoot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\msn7.cat with error 0x57
166.840: GetCatVersion: Failed to retrieve version information from C:\WINDOWS\msn7.cat with error 0x80092004
166.970: GetCatVersion: Failed to retrieve version information from C:\WINDOWS\System32\CatRoot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Tmp.0.msmsgs.cat with error 0x57
166.980: GetCatVersion: Failed to retrieve version information from C:\WINDOWS\Tmp.0.msmsgs.cat with error 0x80092004
167.251: GetCatVersion: Failed to retrieve version information from C:\WINDOWS\System32\CatRoot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Tmp.0.ims.cat with error 0x57
167.251: GetCatVersion: Failed to retrieve version information from C:\WINDOWS\Tmp.0.ims.cat with error 0x80092004
167.391: GetCatVersion: Failed to retrieve version information from C:\WINDOWS\System32\CatRoot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Tmp.0.fp4.cat with error 0x57
167.391: GetCatVersion: Failed to retrieve version information from C:\WINDOWS\Tmp.0.fp4.cat with error 0x80092004
167.822: GetCatVersion: Failed to retrieve version information from C:\WINDOWS\System32\CatRoot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\sp2.cat with error 0x57
167.882: GetCatVersion: Failed to retrieve version information from C:\WINDOWS\sp2.cat with error 0x80092004
175.793: GetCatVersion: Failed to retrieve version information from C:\WINDOWS\System32\CatRoot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Tmp.0.tabletpc.cat with error 0x57
175.793: GetCatVersion: Failed to retrieve version information from C:\WINDOWS\Tmp.0.tabletpc.cat with error 0x80092004
176.434: GetCatVersion: Failed to retrieve version information from C:\WINDOWS\System32\CatRoot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Tmp.0.nt5inf.cat with error 0x57
176.454: GetCatVersion: Failed to retrieve version information from C:\WINDOWS\Tmp.0.nt5inf.cat with error 0x80092004
179.168: GetCatVersion: Failed to retrieve version information from C:\WINDOWS\System32\CatRoot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\netfx.cat with error 0x57
179.168: GetCatVersion: Failed to retrieve version information from C:\WINDOWS\netfx.cat with error 0x80092004
179.939: GetCatVersion: Failed to retrieve version information from C:\WINDOWS\System32\CatRoot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\Tmp.0.mediactr.cat with error 0x57
179.939: GetCatVersion: Failed to retrieve version information from C:\WINDOWS\Tmp.0.mediactr.cat with error 0x80092004
183.404: Copied file: C:\WINDOWS\System32\ntoskrnl.exe
184.075: Copied file: C:\WINDOWS\System32\ntkrnlpa.exe
184.265: Copied file: C:\WINDOWS\System32\HAL.DLL
184.736: Copied file: C:\ntldr
184.926: Copied file: C:\ntdetect.com
185.227: Copied file: C:\WINDOWS\System32\DRIVERS\wstcodec.sys
185.547: Copied file: C:\WINDOWS\System32\DRIVERS\wmiacpi.sys
185.837: Copied file: C:\WINDOWS\System32\DRIVERS\wdmaud.sys
186.348: Copied file: C:\WINDOWS\System32\DRIVERS\wanarp.sys
186.799: Copied file: C:\WINDOWS\System32\DRIVERS\volsnap.sys
187.079: Copied file: C:\WINDOWS\System32\DRIVERS\videoprt.sys
187.340: Copied file: C:\WINDOWS\System32\DRIVERS\viaide.sys
187.600: Copied file: C:\WINDOWS\System32\DRIVERS\vga.sys
187.840: Copied file: C:\WINDOWS\System32\DRIVERS\usbuhci.sys
188.091: Copied file: C:\WINDOWS\System32\DRIVERS\usbstor.sys
188.411: Copied file: C:\WINDOWS\System32\DRIVERS\usbport.sys
188.712: Copied file: C:\WINDOWS\System32\DRIVERS\usbintel.sys
188.972: Copied file: C:\WINDOWS\System32\DRIVERS\usbhub.sys
189.292: Copied file: C:\WINDOWS\System32\DRIVERS\usb8023.sys
189.643: Copied file: C:\WINDOWS\System32\DRIVERS\update.sys
189.883: Copied file: C:\WINDOWS\System32\DRIVERS\udfs.sys
190.154: Copied file: C:\WINDOWS\System32\DRIVERS\termdd.sys
190.364: Copied file: C:\WINDOWS\System32\DRIVERS\tdtcp.sys
190.574: Copied file: C:\WINDOWS\System32\DRIVERS\tdpipe.sys
190.835: Copied file: C:\WINDOWS\System32\DRIVERS\tdi.sys
191.095: Copied file: C:\WINDOWS\System32\DRIVERS\tcpip6.sys
191.466: Copied file: C:\WINDOWS\System32\DRIVERS\tcpip.sys
191.716: Copied file: C:\WINDOWS\System32\DRIVERS\tape.sys
192.036: Copied file: C:\WINDOWS\System32\DRIVERS\sysaudio.sys
192.307: Copied file: C:\WINDOWS\System32\DRIVERS\swenum.sys
192.617: Copied file: C:\WINDOWS\System32\DRIVERS\streamip.sys
192.978: Copied file: C:\WINDOWS\System32\DRIVERS\stream.sys
193.408: Copied file: C:\WINDOWS\System32\DRIVERS\srv.sys
193.759: Copied file: C:\WINDOWS\System32\DRIVERS\sr.sys
194.009: Copied file: C:\WINDOWS\System32\DRIVERS\splitter.sys
194.250: Copied file: C:\WINDOWS\System32\DRIVERS\sonydcam.sys
194.660: Copied file: C:\WINDOWS\System32\DRIVERS\slip.sys
195.151: Copied file: C:\WINDOWS\System32\DRIVERS\sfloppy.sys
195.451: Copied file: C:\WINDOWS\System32\DRIVERS\serial.sys
195.712: Copied file: C:\WINDOWS\System32\DRIVERS\serenum.sys
196.423: Copied file: C:\WINDOWS\System32\DRIVERS\scsiport.sys
196.913: Copied file: C:\WINDOWS\System32\DRIVERS\rndismp.sys
197.164: Copied file: C:\WINDOWS\System32\DRIVERS\redbook.sys
197.594: Copied file: C:\WINDOWS\System32\DRIVERS\rdpwd.sys
197.945: Copied file: C:\WINDOWS\System32\DRIVERS\rdpdr.sys
198.355: Copied file: C:\WINDOWS\System32\DRIVERS\rdbss.sys
198.726: Copied file: C:\WINDOWS\System32\DRIVERS\raspptp.sys
<removed to save space>
5124.178: Copied file: C:\WINDOWS\System32\DllCache\ipconfig.exe
5127.293: Copied file: C:\WINDOWS\System32\DllCache\ipconf.tsp
5129.827: Copied file: C:\WINDOWS\System32\DllCache\intl.cpl
5132.721: Copied file: C:\WINDOWS\System32\DllCache\intelide.sys
5135.395: Copied file: C:\WINDOWS\System32\DllCache\inseng.dll
5137.978: Copied file: C:\WINDOWS\System32\DllCache\input.dll
5140.762: Copied file: C:\WINDOWS\System32\DllCache\initpki.dll
5143.316: Copied file: C:\WINDOWS\System32\DllCache\inetwiz.exe
5146.150: Copied file: C:\WINDOWS\System32\DllCache\inetres.dll
5148.904: Copied file: C:\WINDOWS\System32\DllCache\inetppui.dll
5151.818: Copied file: C:\WINDOWS\System32\DllCache\inetpp.dll
5154.963: Copied file: C:\WINDOWS\System32\DllCache\inetmib1.dll
5157.607: Copied file: C:\WINDOWS\System32\DllCache\inetcpl.cpl
5160.791: Copied file: C:\WINDOWS\System32\DllCache\inetcomm.dll
5163.445: Copied file: C:\WINDOWS\System32\DllCache\inetcfg.dll
5166.389: Copied file: C:\WINDOWS\System32\DllCache\ims.cat
5168.632: Copied file: C:\WINDOWS\System32\DllCache\imm32.dll
5171.396: Copied file: C:\WINDOWS\System32\DllCache\imjputyc.dll
5172.798: Copied file: C:\WINDOWS\System32\DllCache\imjputy.exe
5173.860: Copied file: C:\WINDOWS\System32\DllCache\imjprw.exe
5174.861: Copied file: C:\WINDOWS\System32\DllCache\imjpmig.exe
5176.253: Copied file: C:\WINDOWS\System32\DllCache\imjpinst.exe
5177.826: Copied file: C:\WINDOWS\System32\DllCache\imjpdsvr.exe
5178.857: Copied file: C:\WINDOWS\System32\DllCache\imjpdct.exe
5179.828: Copied file: C:\WINDOWS\System32\DllCache\imjpdct.dll
5181.421: Copied file: C:\WINDOWS\System32\DllCache\imjpcus.dll
5183.113: Copied file: C:\WINDOWS\System32\DllCache\imjpcic.dll
5184.435: Copied file: C:\WINDOWS\System32\DllCache\imjp81k.dll
5185.607: Copied file: C:\WINDOWS\System32\DllCache\imjp81.ime
5187.590: Copied file: C:\WINDOWS\System32\DllCache\imgutil.dll
5190.314: Copied file: C:\WINDOWS\System32\DllCache\imeshare.dll
5192.507: Copied file: C:\WINDOWS\System32\DllCache\imekrmbx.dll
5194.169: Copied file: C:\WINDOWS\System32\DllCache\imekrcic.dll
5195.381: Copied file: C:\WINDOWS\System32\DllCache\imekr61.ime
5197.975: Copied file: C:\WINDOWS\System32\DllCache\imapi.exe
5200.648: Copied file: C:\WINDOWS\System32\DllCache\imagehlp.dll
5203.462: Copied file: C:\WINDOWS\System32\DllCache\ils.dll
5206.477: Copied file: C:\WINDOWS\System32\DllCache\iis.dll
5209.231: Copied file: C:\WINDOWS\System32\DllCache\igmpagnt.dll
5212.105: Copied file: C:\WINDOWS\System32\DllCache\ifmon.dll
5214.568: Copied file: C:\WINDOWS\System32\DllCache\iexpress.exe
5217.593: Copied file: C:\WINDOWS\System32\DllCache\iexplore.exe
5219.976: Copied file: C:\WINDOWS\System32\DllCache\iesetup.dll
5220.888: Copied file: C:\WINDOWS\System32\DllCache\iernonce.dll
5221.148: Copied file: C:\WINDOWS\System32\DllCache\iepeers.dll
5221.418: Copied file: C:\WINDOWS\System32\DllCache\iedkcs32.dll
5221.739: Copied file: C:\WINDOWS\System32\DllCache\ieaksie.dll
5221.969: Copied file: C:\WINDOWS\System32\DllCache\ieakeng.dll
5222.219: Copied file: C:\WINDOWS\System32\DllCache\ie4uinit.exe
5222.530: Copied file: C:\WINDOWS\System32\DllCache\idq.dll
5222.820: Copied file: C:\WINDOWS\System32\DllCache\icwutil.dll
5223.091: Copied file: C:\WINDOWS\System32\DllCache\icwrmind.exe
5223.381: Copied file: C:\WINDOWS\System32\DllCache\icwphbk.dll
5223.621: Copied file: C:\WINDOWS\System32\DllCache\icwhelp.dll
5223.872: Copied file: C:\WINDOWS\System32\DllCache\icwdl.dll
5224.332: Copied file: C:\WINDOWS\System32\DllCache\icwdial.dll
5224.643: Copied file: C:\WINDOWS\System32\DllCache\icwconn2.exe
5224.893: Copied file: C:\WINDOWS\System32\DllCache\icwconn1.exe
5225.144: Copied file: C:\WINDOWS\System32\DllCache\icwconn.dll
5225.404: Copied file: C:\WINDOWS\System32\DllCache\icmp.dll
5225.634: Copied file: C:\WINDOWS\System32\DllCache\icm32.dll
5226.476: Copied file: C:\WINDOWS\System32\DllCache\icaapi.dll
5230.531: Copied file: C:\WINDOWS\System32\DllCache\iasrad.dll
5232.034: Copied file: C:\WINDOWS\System32\DllCache\i8042prt.sys
5234.237: Copied file: C:\WINDOWS\System32\DllCache\i2omp.sys
5236.260: Copied file: C:\WINDOWS\System32\DllCache\i2omgmt.sys
5239.805: Copied file: C:\WINDOWS\System32\DllCache\htui.dll
5241.337: Copied file: C:\WINDOWS\System32\DllCache\hotplug.dll
5243.760: Target File Size Mismatch: C:\WINDOWS\System32\DllCache\hotplug.dll, ExpectedSize = 00023600, ActualSize = 00021800
5245.633: DoInstllation: SetupCommitFileQueue for FileQueue failed: 0x4c7
5249.729: UnRegisterSpuninstForRecovery, failed to delete SpRecoverCmdLine value, error 0x2
5249.729: DoInstallation: Failed to unregistering spuninst.exe for recovery.
5249.729: Service Pack 2 Setup canceled.
Windows XP has been partially updated and may not work properly.
5249.729: Update.exe extended error code = 0xf00d
5249.729: Update.exe return code was masked to 0x643 for MSI custom action compliance.
[svcpack.log]
