I have an old busted laptop which has only two uses: the hard drive, and I *think* the Windows XP Registration Key (the little labels glued to the bottom).
Scenario: I have a CD of Windows XP Home Edition
The laptop is XP Pro.
Could I install the Home edition and use the Key off the lappie? Will it even work? If not, if I wanted to buy a boxed copy of XP Pro, would I be able to install it on two computers, using the second key off the bottom of the lappie on the second install?
I sure hope this hasn't been asked a million times.
