fibroptikl
- Mar 9, 2000
Three hard drives in question:
160
120
400
XP Pro was running on the 160GB. I installed Vista on a 120GB in March.
Now I am going to go back to XP Pro. I erased the 160GB from Disk Management. Then I went and took out the 120 and put in the 160GB.
XP installed fine. I attached my data drive, Seagate NL 35.1 400GB. I went to unmap it as my E:\ and make it D:\ (and make my DVD burner E:, instead of D. Basically switch the two.
I went and clicked remove to remove E: from my 400GB. I hit "Add" and select D: - what the DVD Burner used to be map to.
Then it brought up the following screen:
Then if I go to My Computer and click the D: drive, I get:
Any ideas what's causing this?
160
120
400
