XP for this box?
Cthulhu
what do you think about running xp on this box: PIII 500, 320megs of ram and a radeon 7500 64meg card. so in your opinion, do you think xp would run okay, or is it too old?
BillLeeLee
Sure you can run it. Turn down the visual settings and it'll probably run smooth (probably, since I haven't used a comp slower than 1 Ghz with XP).
Wolf31o2
It'll run just fine, especially with that much RAM. XP is more RAM hungry than CPU intensive.
defcom_1
my laptop (PII 333 w/192MB Ram) runs it fine, I just have almost all the visual stuff turned off...
Smiffy
I'm running XP/Slackware on my P233mmx, 128mb RAM... It's a lot more stable than 9x in my opinion, it's never crashed once on me.
