Ockie said:Thats incorrect. The stock amd heatsinks are 80mm fans and they are panflo fans.
Absolute0 said:I dont see how you could defend the XP90 at this point. Now that there's benchmarks of the new stock AMD heatsink handily matching it in performance
kirbyrj said:1). Not all AMD HSF's are the heatpipe ones they tested there. Those are only on the high end X2's/Opty's, etc. Not on single core chips.
2). The XP-90 can use ANY 80mm or 92mm fan as opposed to the one fan on the Arctic Cooler 64, so if it breaks, you have to buy yourself a new HSF.
I'm not saying that the XP-90 is the best HSF ever. But it does a decent job and is versatile (and it's been out a long time). I've used XP-90's, but for me it's almost time to move on.
I dont know why people always judge their pricing from newegg. Newegg is rarely the cheapest. XP-90 can be found on other sites for $30 shipped. Hello!?!?!!!Absolute0 said:I also realize that the stock AMD coolers they used are only found on the high end CPUs. But still, they are worth very little money, so i dont see how the XP90's performance can justify it's price. It's frigging 45$ at newegg....
Also I am one of the people who did benchmarks comparing the xp-90 w/ 92mm 2500rpm PANAFLO fan to the stock AMD copper heatpipe heatsink. I wasnt defending it. Its still a good budget heatsink even though maybe its not the best. I actually sold my XP-90 and decided to use my stock 165 copper heatpipe sink instead. My temps actually dropped 1C from idle and load with the stock cooler over the XP-90. Not to mention its quieter. Just cause the xp-90 might not be the best, its still a great budget heatsink.Absolute0 said:I know what was wrong: the XP90
Retsam said:Something must have been wrong. 53C load with a venice with an xp-90 isnt normal You must have had high ambient temps or something. I used many different overclock venices on my xp-90, none of them went above 41C at load.
I find indirect comparisons like these, without putting all the facts on the table, to be pretty pointless. Neither of you is even mentioning ambient temp or case temp, both of which can have a big effect on your HSF's performance.Absolute0 said:I know what was wrong: the XP90 Don't say it was contact, i mounted it several times.
Watercooling dropped the temps over 10C and i was pumping way more volts through it. And then i removed the IHS and temps dropped 5C! I was able to Prime95 load with 1.73 volts at ~40C. ... I dont see how you could defend the XP90 at this point. Now that there's benchmarks of the new stock AMD heatsink handily matching it in performance
