38C idle and 44C load, stock HS/Fan. Not sure about room temp because my computer is in an addon and its usually kinda cool in here. 71F though for the rest of the house.
ahhhh sorry missed them its a t-bred and stock volts
but that sould not matter on the temps others get i dont want to see where my temps stand and if i am high low or "just right"
thanks for your help
I'd say those temps are fine, infact the worst your cpu hsf is the better the temps in your room are, as you know the more heat the hsf takes off the cpu, it goes right on into your room.
