XIGMATEK PS shows no -5 V output. Problem?
Hi, gang:
I recently ordered a XIGMATEK 400-W PS (Model PC402) from newegg so I'd have something halfway decent (yet inexpensive) laying around for emergencies, troubleshooting, powering refurb PCs, etc.
I used it to test a PC the other day, and when I connected the PS to my el-cheapo power supply tester, it showed no -5 V output, although all other voltages indicated correctly.
I connected several other junker supplies to the tester to confirm, and each of the other PSs showed -5 V (in addition to all the other usual voltages).
Is this XIGMATEK supply toast?
I haven't tried powering a working PC with it, but I did mention it to XIGMATEK tech support, which hasn't gotten back to me yet about the issue and whether it's RMA-worthy.
What d'ya think?
--Kirk in MN
P.S. I guess I should have tested it prior to the egg's 30-day return period, eh?
plugwash
Those "junker PSUs" must be pretty old, the -5V rail was first made optional and then removed from the spec completely a long time ago. Your PSU is fine unless you are trying to power REALLY old stuff (some ISA cards need -5V).
I find it pretty lame that their tech support doesn't know this though!
Profumo
Aye, the -5v rail was phased out with ATX 2.x in 2002/2003 iirc.. PSUs available now that still have it are Really old designs and literally junk by current standards ;)
Thanks for the info...
I'm a bit embarrassed that I missed the "dropping of the spec," but I'm glad that the PS is probably fine...
The "junker" PS in question is a Sparkle FSP-350-60BT which, as I recall, wasn't really a junker after all. I think it's from 2002-2004, and ya gotta feel good when the FSP-made 350-watter weighs more than most 600-watters.
I don't usually like using PSs that are that old -- even good-quality supplies -- in new builds, but it should still be fine for powering a low-end refurb, etc.
Thanks again for the info!
--Kirk in MN
jeremyshaw
Sparkle was once very good. They were then bought off by FSP, hopefully no effect on Sparkle design, but I dunno. FSP is ODM/OEM. They can make very good units... for other customers. Their own marketed designs tend to be horrible.
It's amazing how a manufacturer's products seem to ebb and flow in quality. I don't remember the details, but I do remember reading about how high-quality and conservatively rated the Sparkle supplies were back in the day. But when I look at the feedback scores today, Sparkle seems to have taken a dive...
I remember how I'd always buy 750-W PC Power and Cooling supplies for my own builds, but now that I'm buying Seasonic, a friend tells me that the latest incarnation of PC Power and Cooling units doesn't match its ancestors in the quality department.
And right now, Brother printers are right at the top of quality and customer satisfaction...and companies like HP, which used to be right there at the top of the mountain, have fallen into the depths...
Ah...keeping track of it all!
--Kirk in MN
Profumo
Don't swallow everything you read.. it's about the hype really, and at the moment that's Corsair and obviously Seasonic... that doesn't mean Sparkle(SPI) is bad, on the contrary, the 85+ series are FSP new Epsilon series, 80+ Silver units with solid performance and exceptional efficiency for their price and rating..
Same is true for the PCP&C units, although the OCZ takeover didn't do them any favors, units like the Silencer 760 and 910 are exceptional performers and(@ newegg) best buys..
[Spectre]
[H] Admin
Staff member
The 80+ Silver Epsilons are not exactly good units.
The 760 and 910 are 2 to 4 year old designs that are consistently outclassed and were "resurrected" after the Silencer MkII's debacle.
Profumo
Well, honestly they're more than good for the price.. yeah, they're group regulated designs but they do extremely well for what they are; The first Epsilons were shitty units, but the 85+ series are a different story, and i guess we can't suspect Gabriel of fowl play in this review which speaks volumes about the platform in question :)
I can't agree with that either Paul, the Seasonic M12D is still one of the best performing, upper mainstream platforms on the market.. with solid build quality, excellent regulation and output quality @ hard to beat prices; it still has better ripple suppression than the AX and most anything else on the market ;)
edit: spelling
[Spectre]
[H] Admin
Staff member
Well, honestly they're more than good for the price.. yeah, they're group regulated designs but they do extremely well for what they are; The first Epsilons were shitty units, but this are from a different story, and i guess we can't suspect Gabriel of fowl in this review which speaks volumes about the platform in question ;)
No, no they don't do really well for what they are. The design is still subpar and are a "buy something else". Also, that review is not of the 80Plus silver units.
I can't agree with that either Paul, the Seasonic S12IID is still one of the best performing, upper mainstream platforms on the market.. with solid build quality, excellent regulation and output quality @ hard to beat prices; it still has better ripple suppression than the AX and most anything else on the market ;)
You can disagree all you want, objectively the 760 and 910 are outclassed by other designs on the market and their relaunch only managed to bring PC Power and Cooling back to where they were quality and performancewise 4 years ago. There really aren't two ways about that.
Profumo
Linked the wrong review ;)
Here you go, might change your mind..
Can you exemplify that with a similarly priced unit that outclasses the Silencer 760 for example!? I'm not a PCP&C advocate, and I agree they don't stand up to the brand image they had in the most part of the last decade, but they're not the trash that the commonly accepted ignorance makes of them..
jeremyshaw
http://www.hardwaresecrets.com/article/Corsair-TX750-V2-Power-Supply-Review/1227/7
same price, actually cheaper after MIR (E: I take that back. it's cheaper before and after MIR)
That, and it kicks the Silencer 760's face in performance. In addition it that, it's slightly smaller (I am eyeballing this based off of the pics, since I cannot find the silencer's specs readily avalible), and it's made by Seasonic.
http://hardocp.com/article/2011/04/27/corsair_enthusiast_series_tx750_v2_psu_review
despite what you said earlier, about Seasonic being a trend, they aren't. They have been consistently good, with only one platform that I know of that performed wierdly under an unsual load configuration (everything 12V, nothing on the other rails...).
[Spectre]
[H] Admin
Staff member
Not likely because, I know the voltage regulation when those units will run is barely in specification to out of specification (which Gabe doesn't tell you). That is when they will run.
Seasonic AT based units, SuperFlower Golden Green based units, etc.
Profumo
Well, the TX V2 is SS-xxxAT, which is an inferior platform to the one used by the Silencer, and the TX V2 is worst in every way, ripple, regulation, efficiency.. what were you trying to prove?..
Now, about Seasonic not being a trend because they're generally good to excellent, i never said they weren't.. but that doesn't make them the only solid choice available and by no means does it invalidate anything else available on the market, and that is exactly what you see in pretty much every discussion on the topic, if it's not Seasonic it's not worthy of attention, and that is pure ignorance..
edit: spelling
Profumo
That is an 80 Plus Silver 600W 80$ unit on newegg, in my book that's a deal :)
Golden Green is just excellent, but in a different pricing league, while SS-xxxAT is inferior to M12D in every single way ;)
[Spectre]
[H] Admin
Staff member
No, the AT platform does not perform better than the M12D design used by the Silencer 760 and 910, which is a fact you should know as well as anyone else.
The AT has better voltage regulation and even to better DC output quality than the S12D. Other than that, sure why not the S12D is better.
jeremyshaw
edit: spelling
lol, I based it off of the review you linked :p
Why the hell did you even bring up the silencer, and link a review to a piece of shit?
Profumo
Only slightly better than the 910 watt unit, which is a stretch for the platform... otherwise the M12D is superior, as is should be, it's more expensive..
Zero82z
The S12D has better voltage regulation and they are about equal in output quality. The S12D is also more efficient. For the sake of a direct comparison, here are reviews of both PSUs by the same person:
http://www.pcper.com/reviews/Cases-and-Cooling/PC-Power-Cooling-Silencer-760W-Power-Supply-Review'
http://www.pcper.com/reviews/Cases-and-Cooling/Corsair-Enthusiast-TX750-V2-and-TX850-V2-PSU-Review
[Spectre]
[H] Admin
Staff member
And crmaris gets them at a push, and the units I have tested the AT did better (Oklahoma's AT units also do significantly better than Lee's). :eek:
Zero82z
Yes, Jeremy's did do better, but taking into account unit by unit variations and the fact that we're talking under 2% regulation in almost all cases, it's basically a wash between the two platforms aside from efficiency, in which the S12D does better.
[Spectre]
[H] Admin
Staff member
Zero82z
Alright, so now we've established that your original statement that the AT platform is better was incorrect, and that your later statement that it has better voltage regulation and DC output quality was also incorrect, and that the S12D platform is indeed better overall than the AT platform. I'm satisfied.
Profumo
I read the thread, it was a lot of useless back and forth, with a challange at the rear end. So I took the challange for what it was worth at face value :p
Oh come on, it was a lame out, and while being wrong is not something easy to admit, you should try it sometimes ;)
jeremyshaw
Oh come one, it was a lame out, and being wrong is not something easy to admit.. you should try it sometimes ;)
only to you, for me, I stand by what I have said. Of course, you're part of why I didn't read the whole thread :p Then again...nvm, keep replying.
Profumo
lol, you knew exactly what you were contradicting, you simply didn't knew that you were wrong.. it happens ;)
jeremyshaw
Or better yet, I got into a thread of people who took my initial speculation on potential Sparkle quality the wrong way.
Profumo
The argument in question has nothing to do with Sparkle.. but with TX V2 vs Silvencer;), anyway, you should quit while your behind, your contribution to this thread ended at post no 5 :)
Zero82z
Or better yet, you jumped into a thread about a subject you don't know about, and started posting incorrect statements.
jeremyshaw
It's about to end near 20 (if I counted correctly).
EDIT: I didn't.
[Spectre]
[H] Admin
Staff member
It has better voltage regulation and better to even DC Output quality like I said. Conveniently making it a wash because it is within an arbitrary value in the end to erase the differences doesn't change the numbers ;)
Zero82z
Except that is obviously not a consistent result, since Lee's sample had worse voltage regulation. I could spend all night pulling data from AT and S12D reviews only to conclude that on average they have about equivalent voltage regulation, but quite frankly that would just be even more of a waste of time than posting here in the first place.
merliwolf
You guys just need to agree to disagree.
But honestly I find it really sad that PC Power makes a comeback using 4 year old Seasonic Models. Is that really supposed to be a comeback? If you're going to be a supposed top of the line psu maker, shouldn't you have 80plus gold/platinum psus with extremely good ripple and regulation? I don't see that from them, I see basically copies of all the other psu resellers.
Profumo
Well, Steve Lee(the guy responsible for Corsair's PSU division and its success) recently got back to OCZ, so cool things are to be expected from PCP&C in the near future ;)
merliwolf
Meh the proof is in the pudding. Also even if they actually come out with something good, I'm more than satisfied with seasonic, corsair, and antec anyways. It'll take a long time for them to win me over, that's for sure.
