distortion69
- May 1, 2007
So the Hyper212 wasn't on sale.. so I sprung for the cheaper cooler because I didn't want to spend $40 on a cooler. So I gambled, and basically... I am really impressed with this $24.99 cooler. It mounts very well and feels very sturdy, the fan mounting rubbers are extremely stretchy so the fan took less than 30 seconds to install. The unit itself took about 10 minutes, it was pretty self explanatory. I ordered it Tuesday, it was here Thursday.. Once again Newegg comes through
Here were my results @ 4.0ghz, 1.304volts, on the turbo 4.0 settings on my mb for 5 minutes.. room temperature roughly 71 degrees
Stock 2500k cooler -
core 1 - 78
core 2 - 84
core 3 - 86
core 4 - 83
Loki 92mm
core 1- 53
core 2 - 55
core 3 - 53
core 4 - 51
WOW! I didn't know my stock fan would get that hot with stress testing. The highest I had seen it in core temp which I left on all the time was around 74 degrees. So it's a good thing I got a replacement. The thermal paste was with whatever was supplied with each...
One more result... after hearing that the turbo 4.0 uses quite a bit more voltage than necessary, I went ahead and did a manual overclock of 4.4ghz @ 1.256volts. It has been running for about 45 minutes now with no stability issues.. here are the temps:
core 1 - 52
core 2 - 53
core 3 - 55
core 4 - 49
I was really excited with these results, because I didn't think I could get a stable O/C at this voltage.
I know there is nothing magical about this cooler, it's less surface area, with a smaller fan... but it works well for the dough, so I thought I'd just post with my results in case anybody gave a crap
Josh
core 1 - 78
core 2 - 84
core 3 - 86
core 4 - 83
Loki 92mm
core 1- 53
core 2 - 55
core 3 - 53
core 4 - 51
core 1 - 52
core 2 - 53
core 3 - 55
core 4 - 49
Josh
