XGI Volari Duo V8 Ultra
Discussion in 'Video Cards' started by erek, Jun 26, 2018.
  1. erek
    erek 2[H]4U
    2,294
    Dec 19, 2005
    Just purchased this open box Volari
  2. pendragon1
    pendragon1 [H]ardForum Junkie
    11,185
    Oct 7, 2000
  3. erek
    erek 2[H]4U
    2,294
    Dec 19, 2005
    pendragon1 likes this.
  4. erek
    erek 2[H]4U
    2,294
    Dec 19, 2005
  5. GiGaBiTe
    GiGaBiTe Gawd
    663
    Apr 26, 2013
    United Chemi-Con KZG series capacitors strike again. I can just see the KZG model on one of the brown caps near the back of the card. I used to replace so many KZG/KZE caps that I kept a bag of them, it got so ridiculous that I finally had to toss them because the bag was getting to be several pounds.
    I can definitely recap that card for you. I'd recommend replacing all of the capacitors because it looks like most of them are types known to fail.
    Since I'd order a kit of capacitors for this card, would you want electrolytics or polymer caps? Poly caps are more expensive but tolerate heat better and last longer.
    atp1916, {NG}Fidel and erek like this.
  6. {NG}Fidel
    {NG}Fidel [H]ardness Supreme
    5,836
    Jan 17, 2005
    I need to learn this skill. Time to pick up busted old cards and learn the smart way
    erek likes this.
  7. GiGaBiTe
    GiGaBiTe Gawd
    663
    Apr 26, 2013
    You also need the right equipment. At minimum, you'll want a soldering station (with a decent wattage iron like 40-60W), hot air tool and a desoldering gun; Preferably one with a electric vacuum pump because those spring loaded ones can cause damage to the PCB. The two most common types of damage are freezing air pockets inside through holes or ripping pads/traces off the board. A desk magnifier also really helps with tiny SMD components, here's my setup:
    (I was replacing a burned DDR slot on the board on the bench)
    You'll also want a bottle of good flux with a syringe for application, never heat an old solder joint dry because it usually won't melt and you'll end up damaging the board and components with excessive heating. I'd also recommend never using lead-free solders as they don't melt properly, flow terribly and usually have mechanical issues due to not being as ductile as 60/40 or 63/37 leaded solder.
    A setup like this will set you back several hundred dollars, but it's well worth it because you can work on even the most stubborn boards. I can do through hole and most SMD work with this setup, but not BGA since I don't keep stencils, the balls or paste around for it.
    erek and {NG}Fidel like this.
  8. Stoly
    Stoly [H]ardness Supreme
    6,181
    Jul 26, 2005
    That's an AGP card, right? Got a mobo for it?
    I'm curious to see if you can bring it back to life.
    erek likes this.
  9. GiGaBiTe
    GiGaBiTe Gawd
    663
    Apr 26, 2013
    I repaired one of his AGP boards awhile back.
    erek likes this.
  10. Stoly
    6,181
    Jul 26, 2005
    Nice, done any testing?
    erek likes this.
  11. auntjemima
    auntjemima [H]ardness Supreme
    4,218
    Mar 1, 2014
    erek I want to know what he paid for it out of the box like that.
    erek likes this.
  12. erek
    erek 2[H]4U
    2,294
    Dec 19, 2005
    Not yet, has some capacitors that need replaced first
  13. jaffy
    jaffy [H] Custodian
    5,569
    Jan 13, 2004
    I'm so jealous. Was looking for one of those cards a while back when I was into collecting, had an open post in FS/FT for years.
    auntjemima and erek like this.
  14. erek
    erek 2[H]4U
    2,294
    Dec 19, 2005
    revenant, Slaventus86 and auntjemima like this.
  15. auntjemima
    4,218
    Mar 1, 2014
    lol 2nd one. Most cannot even find one. :)
    Elmy and erek like this.
  16. atp1916
    atp1916 [H]ard|DCoTM x1
    3,674
    Jun 18, 2004
    WTG erek. Happy to see you winning.
    Are the Parhelias worth anything (from your experience)?
    erek and auntjemima like this.
  17. erek
    erek 2[H]4U
    2,294
    Dec 19, 2005
  18. GiGaBiTe
    GiGaBiTe Gawd
    663
    Apr 26, 2013
    Now you just need one of those quad AGP boards used for 4x V5 6000 SLI to run 2x2 Volari ultra power111!
    You said you aren't going to open the sealed one, I would anyway because if any of the electrolytic caps start leaking, it's going to eventually destroy the board (usually by seeping in the vias and delaminating the board.)
    revenant and erek like this.
  19. Maddness
    Maddness [H]ard|Gawd
    1,159
    Oct 24, 2014
    Love the wind effects. That had me cracking up.
  20. Elmy
    Elmy Gawd
    927
    Sep 1, 2009
    I have connections. Don't really want to say my source. But I was happy to help Erek out with both of these. Love guys with a passion for collecting this stuff and helping keep the history alive.
    As far as I know there hasn't been one for sale on any Ebay , forum etc.. around the world since 2011. Thats how rare one of these are and I was able to find Erek 2 of them.
  21. auntjemima
    4,218
    Mar 1, 2014
    Lol, thats awesome. I would never ask for a source anyway, even though I love collecting as well. Sometimes secrets are better kept ;)
    erek likes this.
  22. revenant
    revenant [H]ardForum Junkie
    14,136
    Apr 10, 2005
    These card collector threads are great. I have a decent stash of old and rare-ish cards... I have a bunch in a sealed tote and I am not even sure how many.. Lots of Geforce4 Ti and FX cards.. Some ATI and 3DFX cards.. Actually I really need to inventory my 3DFX voodoo cards.. I know I have an Intense 3D Voodoo 6MB EDO 3DFX Rush TV PCI (intergraph) and I haven't seen it for a long time... I also have a boxed (with manuals and floppies) Gravis Ultrasound Max.. I think it's time to take them all out and post some pics. :)
    auntjemima, erek, {NG}Fidel and 2 others like this.
  23. erek
    erek 2[H]4U
    2,294
    Dec 19, 2005
    I took a gamble on the bulging capacitors and fired her up
    revenant and Maddness like this.
  24. Maddness
    1,159
    Oct 24, 2014
    It lives
  25. revenant
    14,136
    Apr 10, 2005
    Love seeing those blue led fans spin up!
    Maddness and erek like this.
