[H]adouken
- Dec 31, 2008
Not sure who to buy from, they are all great. I like XFXs designs the best, I want the card the overclocks nicely too (hopefully I can flash one of their BIOSes into a BIOS that allows heavier overclocking).
XFX: http://www.newegg.com/Product/Product.aspx?Item=N82E16814150334
- Advantage: $350
XFX: http://www.tigerdirect.com/applicat...?EdpNo=4394538&csid=ITD&body=MAIN#detailspecs
- Advantage: $380, XXX Edition (670MHz)
BFG: http://www.newegg.com/Product/Product.aspx?Item=N82E16814143168
- Advantage: 666MHz, but $380, seems worse than above. Tradeup.
EVGA: http://www.newegg.com/Product/Product.aspx?Item=N82E16814130442
- Advantage: None, besides step-up.
Which of these would you pick? Please post deals/links of your own if you have them. Leaning towards XFX, and hopefully can OC to 700MHz myself, but never heard of XFX having a stepup program like the other two. Don't need a step up though, as GTX 285 is the new king, and will probably be good for a very very long time.
- Advantage: $350
