Xeon E5-2667 v2 - 4.1ghz all 8 core turbo, 4.5ghz single - 114mhz BCLK
Discussion in 'Intel Processors' started by manbat, Mar 12, 2018.
  1. manbat
    manbat n00bie
    10
    Mar 11, 2018
    Oh hi Hard
    Just wanted to let you know I've got at stable overclock of 114mhz BCLK on a Xeon E5 2667 v2, which means a neat 4.1 all core turbo and 4.5 single core turbo. :) And all on stock turbo voltage.
    The most impressive thing IMO is the cooling, overclocked at 114mhz BCLK it never got hotter than 50 degrees under benchmarks (stock temps are off, forgot to open OHM before the tests).
    114mhz:
    100mhz:
    I was coming from an i7 4790k delidded at 4.5. No difference in games what so ever.
    100mhz Xeon E5 2667 v2
    bf1 - 101fps
    skyrim - 42fps
    114mhz Xeon E5 2667 v2
    bf1 - 102fps
    skyrim - 43fps
    i7 4790k
    bf1 - 100 fps
    skyrim - 41 fps
  2. AgentNein
    AgentNein n00bie
    16
    Apr 17, 2016
    Arg, don't let them know that. I was hoping to put two of these in my dual 2011 soon at a cheaper price.
  3. manbat
    manbat n00bie
    10
    Mar 11, 2018
    Is that system used for gaming or virtualization? I think you should go with dual E5 2680 v2 instead, unless you use it for gaming. 2680v2 are cheaper (~180$ vs ~250$), more cores and lower TDP. :)
    If the 2680 v2 ever comes below or at 100$, they are a steal.
  4. Aluminum
    Aluminum Limp Gawd
    464
    Sep 18, 2015
    Neat, but on an X79 board the 1680v2 is identical (8c/16t 25MB L3) and straight up unlocked. Mine does 4.5 without a single tweak.
    If you could get this working on a dual board somehow it would be impressive.
    gigatexal likes this.
  5. manbat
    manbat n00bie
    10
    Mar 11, 2018
    The 1680v2 is a lovey chip, but sadly it's very expensive, ~500$ on the bay. At which price did you get yours?
    And the first '1' in the product name, means it's a single socket CPU. E5 2xxx means dual, E5 4xxx means quad and so on (but I'm sure you already know that :)).
  6. thecold
    thecold Limp Gawd
    158
    Nov 12, 2017
  7. cdabc123
    cdabc123 [H]ard|Gawd
    2,000
    Jun 21, 2016
    holy hell. I have the sr-x motherboard and two 2670's and i couldnt get them above a 103 bclk. a 114 would be fantastic with a pair of 2687w's
  8. manbat
    manbat n00bie
    10
    Mar 11, 2018
    Funky. I've heard the V2 are easier and more forgiving to BCLK clock than the V1s, you might want to consider getting some V2's, if you are to BCLK clock them. :)
    Freebay Xeon E5 2680 v2:
    https://www.ebay.com/itm/Intel-Xeon...477471&hash=item440e6109a7:g:yc4AAOSwE-lZ6FDm
  9. AgentNein
    AgentNein n00bie
    16
    Apr 17, 2016
    2680v2's my second option. I deal with a few programs heavily where there's diminishing returns after 16 cores. I'll probably settle for the cheaper solution. At least I have a pair of E5-2670s and E5-2643s to sell off.
  10. Aluminum
    Aluminum Limp Gawd
    464
    Sep 18, 2015
    $900 over two years ago. And on X79 there is no difference between any E5 but I'm sure you already knew that ;) Some programs like cpu-z even think mine is a 2690v2, the die is from a 10-core with 2 cpus disabled but all L3 enabled. The HCC chips all have the QPI links needed for 4-way SMP, intel just turns them off for different skus.
  11. manbat
    manbat n00bie
    10
    Mar 11, 2018
    Damn, that's expensive but still it's a nice chip. The high end E5's are indeed all so similar :)
    Are you running 4.5ghz on all 8 cores for the past 2 years then? stable?
  12. AgentNein
    AgentNein n00bie
    16
    Apr 17, 2016
    It's a shame I'm only just now learning about this board. I have a nice, stable Asrock EP2C602 server board, but arr. Still think the endgame for this particular system is the E5-2667v2s or 2687Wv2. Just gotta keep riding the gpurampocalypse with ECC DDR3.
  13. Jayy88
    Jayy88 [H]Lite
    109
    Mar 9, 2018
    I got a Xeon 5650 here no idea if its good. Need board that could run it...idk some newer china examples that saying it can, idk lower phase board 10-12phase...
    find one that does that's gawd on 1366.
  14. manbat
    manbat n00bie
    10
    Mar 11, 2018
    Damn, that's a thicc board! The one with SFP+ modules and 16 memory slots?
    E5-2667v2s or 2687Wv2, just get what ever is cheapest. There's no real performance difference, both have all core turbo at x36.
    Got my 2667 v2 from this seller, the chip arrived 5 days after i ordered it - freaking amazing: https://www.ebay.com/itm/Intel-Xeon...573634?hash=item23963f1bc2:g:~pUAAOSwW6BaRNFQ
    16GB ECC DDR3 (ebay) = 60$, 16GB DDR4 (new) = 250$
    get rekt
  15. AgentNein
    AgentNein n00bie
    16
    Apr 17, 2016
    Nah, I just have a vanilla with 8 slots and 32GB ECC RAM that I think cost less than $50 when I bought it. I'll keep an eye out for that 2667v2. Thanks!
  16. manbat
    manbat n00bie
    10
    Mar 11, 2018
    The Xeon X5650 can easy hit 4.0 with a good board, but a good used board is hard to come buy. Look at your local equivalent for Craigslist for used systems with a shitty i7 920 and a good motherboard.
  17. Edloma
    Edloma n00bie
    2
    May 13, 2018
    [QUOTE = "manbat, post: 1043530165, miembro: 308593"] Oh, hola, duro
    Solo quiero que tenga un overclock estable de 114 mhz BCLK en un Xeon E5 2667 v2, lo que significa que no hay nada 4.1 turbo núcleo y 4.5 turbo núcleo único. :)Y todo en stock turbo voltaje.
    Lo más impresionante de IMO es el enfriamiento, overclockeado en 114 mhz BCLK, nunca estuvo más caliente que 50 grados bajo los puntos de referencia (las temperaturas de stock son apagadas, se olvidó de abrir OHM antes de las pruebas).
    Hola Manbat, ¿podrías compartir cómo lo hiciste?
    También tengo ese procesador y me gustaría llegar más velocidad de reloj.
    Un bclk a 114 puede afectar negativamente a otros componentes de la PC, como los discos?
    No tengo práctica en overclocking, si me lo explicas, te agradecería
    Gracias
  18. Edloma
    Edloma n00bie
    2
    May 13, 2018
    I'm sorry the Google translator translated the text!!!
  19. manbat
    manbat n00bie
    10
    Mar 11, 2018
    Hi Edloma
    You must have a decent x79 motherboard. I have a ASUS P9X79 Pro. Which motherboard do you use?
    BCLK does have a tradeoff with PCIe cards. My GTX 1070 works fine, but i tried with a LSI 9212-4i4e and a 10Gb Melanox SFP+ network card and these 2 only worked at 100mhz BCLK.
    I got 5 SSDs in the system, 1 boot 250GB, 2 250GB in RAID 0 and 2 500GB also in RAID 0. The arrays are created using Windows Disk Management. Never have i experienced any dataloss, just rock stable performance. I do have Veeam endpoint to my storage server to backup the RAID 0 arrays, as dataloss will ocur if 1 disk fails.
