XenCenter Usage Meter Issues
tgray96
OK, So I am running: XenServer 6.1.0 when connecting with XenCenter via LAN, It gives me the usage information:
But when I connect from my home, I get no usage stats:
I have port 443 forwarded.
Metraon
You should contact XEN and/or go to their forums and/or post on the hard virtualisation subforums, prehaps you will get more luck on this side.
I have read some place, that NTP have to be configured and time should be synchronised, also prehaps it is a proxy issue on the production network ?
tgray96
NO, there is no proxy. It could be a NTP issue, although, I have reset the NTP settings on the xenserver. Thanks.
