Humm, my buddy's new XBox One X has died - played it for about a month and then it would not turn on any more. It turns out to be an issue with the provided power cable.
"The default cable included with the console is rated at 7 amps and 125 volts, while the replacement cable is rated 10 amps and 125 volts. In other words, any cable rated 7 amps or more and at least 125 volts should fix the problem" ... "Keep in mind that by using a third-party power cable, you risk voiding your warranty, so proceed at your own risk"
Fix your Xbox One X shutting down and not turning back on issues
http://windowsreport.com/fix-xbox-one-x-wont-turn-on/
Did your Xbox One X suddenly stop working? Maybe it’s a bad power cable
https://www.onmsft.com/news/did-your-xbox-one-x-suddenly-stop-working-maybe-its-a-bad-power-cable
"Xbox One is designed to be plugged directly into a wall outlet"
Any qualified Electrical Engineer knows that the quickest way to destroy an electrical device such as an XBox or even speakers is to under power them - this is very, very bad Microsoft ... basic electronics 101.
- The default cable included with the XBX console is rated at 7 amps and 125 volts, while the Nyko cable is rated 10 amps and 125 volts but voids the warranty.
- How on earth am I suppose to figure out if I'm getting the proper amps and volts through my XBX power cable or not and how in the world am I suppose to just "know" not to use a surge protector for the XBX to plug straight in to a wall outlet instead, especially when we get power surges fairly often?
- Most average homes only have a certain number of outlets in each room - usually just 4; often just one on each wall in an average size bedroom so, what Microsoft/XBox is asking is just not reality and was not thought through very well.
- What about plugging the XBX into a battery backup? We get power surges fairly often around here. What battery back up and surge protectors would be approved by Microsoft?
- My friends' new XBX stopped working due to the power cable issue; mine still works but how am I suppose to know if it has already been damaged in some way or not due to the power requirements?
- Microsoft says using a different power cable voids the warranty- then we need a Certified cable approved by Microsoft
- Microsoft needs to do the right thing and do a re-call on the XBX power cord and offer a Certified 10 amp 125 volt replacement
Nyko AC Power Cord
https://www.gamestop.com/accessories/nyko-ac-power-cord/1975
- Unplugging the XBox One X from a surge protector and then plugging directly into a wall outlet is *NOT* a solution - it is merely a temporary fix until a new XBox One X cable rated at 10 amps and 125 volts Certified and approved by Microsoft is availabe as a replacement
Don't daisy-chain surge protectors because it decreases power and could cause under-power damage
Nyko AC Power Cord
