xbox 360 wireless controller
Discussion in 'General Gaming' started by K10, Mar 5, 2006.
  1. K10
    K10 2[H]4U
    3,308
    Mar 28, 2005
    i don't have an xbox...so i'm wondering if the xbox 360 wireless controller will work on a pc?
  2. Xipher
    Xipher 2[H]4U
    2,621
    Mar 15, 2004
    All reports I have seen say no. The USB charging adapter only charges the controller.
  3. Stormlifter
    Stormlifter 2[H]4U
    2,968
    Oct 19, 2002
  4. RancidWAnnaRIot
    RancidWAnnaRIot EspantaPajaros
    11,039
    Feb 19, 2004
    i'd just like to add.. that the X360 controller works well with a PC though.. i love it....
  5. Stormlifter
    Stormlifter 2[H]4U
    2,968
    Oct 19, 2002
    Yeah I'm hoping to buy one from someone... no luck so far
  6. inZane
    inZane Limp Gawd
    319
    Apr 11, 2006
    Why would you wait to buy a 360 Wired controller from someone?? they are not all that expensive and work extremely well on a PC. sure, they are a bit more expensive than a Gravis or other gamepad, but the quality of the 360 controller is excellent.
    My advice, suck up the cost and get one brand new. :D
  7. killedaway
    killedaway Limp Gawd
    314
    Feb 16, 2006
    i've read on a couple of the rumor blogs that Microsoft will be releasing a USB dongle to use wireless controllers on your PC. that's probably a ways off, so don't wait. it's just kind of a cool thought.
  8. Yaka
    Yaka Gawd
    614
    Jan 26, 2004
    i hope they release a wire less module. if not then atleast some smart arse to atleast figure out a way of uising the wireless x360 pad with a pc.
  9. theNoid
    theNoid [H]ardness Supreme
    7,438
    Dec 23, 2003
    The wireless controllers communicate with the 360 on a lock after calibrated ... they are not designed to even work for a PC. The controller is the best I've ever held, and if you want one for your PC... buy a wired one.
