not to try and be a thread crapperFurhead said:Hey guys i have heard rumors on the internets that you can hook the 360 up to lcd monitors. I have the Dell E207WFP , Wide 20 Inch Flat Panel, will the cables that come with the premium 360 work on it?link
Yes, but also any monitor that has both DVI and VGA inputs....simply use DVI to your video card and the VGA cable for the 360. Looks fantastic on my 2007FPW through VGA.Buckweed said:can you hook up your 360 to that particular model as shown in the link? just using the VGA adaptor ?
I might get that one aswell.
do you notice any banding problems?joemama said:Yes, but also any monitor that has both DVI and VGA inputs....simply use DVI to your video card and the VGA cable for the 360. Looks fantastic on my 2007FPW through VGA.
Only when I run certain banding tests....never in normal use. Banding only shows up using DVI anyway, VGA doesn't have that problem for some reason.Mhiero said:do you notice any banding problems?
Or buy them used at gamestop for $15, you dont get the gender changers but its alot cheaper.note235 said:compusa or bestbuy-$39.99 plus tax
