mmmmmdonuts
- Oct 7, 2009
So I downloaded and installed XBMC version 10 and everything is working perfectly, except one stuttering issue when I use an MPC-HC as an external player in XBMC. I only use it when I am trying to play a ripped bluray (for the lossless audio) and it opens and closes perfectly fine, but it just stutters during playback. When I just play the bluray normally in MPC, it works flawlessly even with the HD audio.
My system is a e6750 w/ 8gb ram and a 5450 GPU. Neither the cpu or gpu is stressed to the max while playing this so I was wondering if anyone is experiencing this or has this issue at all? If you have I would love to know how you solved it Thanks for the help.
