X9SRH-7TF's LSI 2308 prevent me from booting
Discussion in 'SSDs & Data Storage' started by Mastaba, Apr 28, 2019.
  1. Mastaba
    Mastaba Limp Gawd
    228
    Apr 2, 2011
    I have a PC with X9SRH-7TF motherboard that i don't reboot very often. (a few times a year at most)
    Yesterday i did it and the boot is now stuck on the "LSI Corporation MPT2 boot ROM successfully installed!" message.
    (The mobo has some LSI 2308 controller connected to the drives)
    I tried waiting, restarting (the PC is not frozen, i can CTRL-ALT-DEL and reboot again).
    I can't enter the BIOS because it's a step after the error i have.
    The boot SSD and others HDDs are correctly recognized, i can go into LSI's menu with CTRL-C but there's not much to do and everything appear to be normal.
    What happen? how can i fix it?
  2. Aluminum
    Aluminum Gawd
    617
    Sep 18, 2015
    If you don't need to boot from drives attached the the LSI controller, there is a way to reflash them with no boot rom image installed to get in the way. IMO this is the best configuration choice when using them as plain HBA controllers anyways.
