chemist_slime
- Jul 24, 2005
Will be trying these this weekend.
I'm running the L9x65 on a 5930K with a 92x25mm fan…
Contact ASRock about that? They might be able to give you a beta BIOS with added functionality like they did me a while back.
I just submitted a support ticket and didn't reach out to anyone specific.Who did you reach out to at asrock? I typically just ask them on their forums but I heard they have't been that responsively lately.
Did you ever find a solution for getting the larger DIMMS to work?I just emailed them. I was hopeful and also tried some 64GB DIMMS, 2400 Mhz from Samsung Load Reduced and it had the same issue as the 128GB DIMMS. Hopefully they can give me a beta bios that works for both! Thank you.
Hi!!!!
I was using water cooling from 4 years ago, but now I would like pas to a simple air cooling by my job, every 3/4 months I need change to the city and home. With water cooling are dangerous by problems if water exit from pipes.
So, for this change I have dudes about temps and good work with Asrock X99 ITX and i7-5930K. Well I read about Noctua NH-C14 is a good cooler. Before buy this cooler and NCASE I would like know your knowns and predictions about temps and works.
My hardware:
I use my pc to games (around 3 hours day), watch films, web, AutoCAD 2D/3D, stream, office works & other tasks...
- CPU: I7-5930K
- P.B.: Asrock X99e ITX/ac
- GPU: PENDENT NEW GPUs
- RAM: G.SKILL Trident Z 32GB (16x2GB) 3200MHz
- M.2: Samsung 950 Pro 512GB
- SSD: Samsung 840 EVO 750GB
- HDD: Western Digital Caviar Green 3TB
- F.A.: Corsair SF600
- Caja: PENDENT
A lot of thanks for your help
Regards, JaPeMo
Hi JaPeMo,
I have a similar setup I put together recently which should be a good example of those temps you'd expect.
Case: Ncase M1 v5
Mobo: Asrock x99-itx
CPU: 6800k overclocked to 4.1hz at 1.27v
Cooler: Noctua U9DXi4
During my stress testing with Aida64 on the cpu, my temps would peak at 60C after an hour or so. When running Aida64 and running an open air gtx770 the cpu temps peaked at 70C, but stayed in the low to mid 60s.
Keeping in mind that those temps are worst case scenarios, your everyday temps should be much better. For example, while watching movies while internet browsing, temps hover in the high 20s to low 30s.
The C14 is a better cooler than mine too. Really the cooling performance you need depends how many volts you are comfortable pushing at your cpu. If you are confortable with higher voltages such as 1.4 needed for even higher overclocks then you may need that extra cooling performance.
I too came from AIO watercooling, and haven't looked backed since.
Hope it helps!
Only possible with a Xeon at the moment, but the E5-1650v3 is unlocked if your goal is overclocking. 32GB modules are probably a ways away. 16GB ones only just came out about a year ago I believe. If you switch to a Xeon, you can go all the way to 256GB in this board actually.Anyway to get 64GB working on a 5930K? How long until we get 32GB non Reg modules?
What temp you have in ambient (winter or summer) ?
Thanks for your help!!!
I recall my thermostat was reading 75F. As it's a new system I can't say what it'd be like in the summer, but I live in a warm climate.
You're welcome!
Hi JaPeMo,
Case: Ncase M1 v5
Hope it helps!
Hey Neapolitan6th, I'm looking into a remarkably similar build to yours at the moment it seems, and just trying to figure out the RAM clearance in reality under the U9DXi4 with the x99 mobo
I'm looking at Vengeance LPX 16Gb x 2 to max out the board, but they quote 33mm height, and Noctua suggests 32mm clearance maximum for the U9DXi4. To spice it up I found a Tomshardware article suggesting there might be up to 35mm clearance! (I can shoot you the link, trying not to break the <3-post-link rule or it should come up typing in "U9DXi4 Tomshardware" into google).
What RAM did you go for in your build and what was the clearance like?
Thanks in advance, I've been sweating the cooling on this thing for an age!
OSX 10.11.6
That is a pretty nice HackPro you got there…!
Can you get Sierra working on X99E-itx?Yes Boil! It's an HackPro...and it really rocks!
Outperform every trashcan you can buy from Apple...and cost me 1/3 of the best best trashcan![]()
Well...i've tried only very first builds of Sierra...and decided to stay happy where i'm now!Yes. Not just that, Sierra works much better for me than 10.11.
Interesting. Among other things I was never able to get USB 3 to work on 10.11, but it works flawlessly under 10.12. Did you have any problems with that?Well...i've tried only very first builds of Sierra...and decided to stay happy where i'm now!
But Yes, Sierra works on X99E-ITX!![]()
Huh, that's curious. I had the Asmedia 3.1 ports working (although not sure if at 3.0 or 3.1 speeds), but enabling the Intel 3.0 ports always gave me a kernel panic at boot in 10.11. Both Intel and Asmedia are working in 10.12 though, again not 100% sure if the Asmedia ones are at 3.1 speed or 3.0.USB 3.0 works fine under ElCap on this mobo, USB 3.1 NO.
So...3.1 works fine and stable on Sierra?
Lets add thunderbolt 3.0 to that.
My favorite would be some crazy way of adding another pcie 3.0 connector to the thing that would work with riser cables.
"adding another pcie 3.0"...i think Neapolitan6th is dreaming about 2 pcie 3.0, 1 with a gpu...and another one with some m2 in raid?The PICe 3.0 on this mobo already works with riser cables. Dan has a X99 mITX build with his A4 case.
Well, if so, it's better than my "double m2 dream"!![]()
If only.. If only..
Interesting but...my titan x at 8x....mmmmmmWell the PCIe 3.0 x16 on the Asrock X99 ITX mobo can be bifurcated to two PCIe 3.0 x8, that's more than enough for running a GPU and some other devices.
Interesting but...my titan x at 8x....mmmmmm![]()
