x99 ITX Build
Discussion in 'PC Hound System Builder' started by ///AMG, Jan 4, 2017.
  1. ///AMG
    ///AMG 2[H]4U
    2,640
    Sep 19, 2012
    I am looking at building a system to replace my current workstation/gaming rig, I do a lot of things that benefit from more cores and I dont play games very often. I want it to be semi portable, I dont plan on moving it too often but I do see the need to move it once a month so I am trying to go with an ITX build. Mostly because I dont want a huge tower anymore.
    So far I plan on getting the following unless there are big issues or concerns raised:
    Asrock X99E-ITX/ac - Bought
    Intel Xeon E5-2683 V3 - bought
    ncase m1 - bought
    Corsair H75 bought
    Corsair LPX Bought
    Silverstone SX700-LPT bought
    Parts from current system to be carried over:
    Gigabyte GTX 1070
    850 and 840 pros
    Need suggestions on:
    M.2 ($200) - Waiting on a deal, not in any rush, might get another 2.5" ssd as well
    Any suggestions and concerns that I should consider?
  2. {NG}Fidel
    {NG}Fidel [H]ardness Supreme
    4,888
    Jan 17, 2005
    Corsair SFX600W or SilverStone SFX 600W.
    RAM Just grab 2x32GB sticks and call it a day.
    M.2. 960Pro or 950Pro.
    Cpu Cooler Corsair H75.
  3. chx
    chx Limp Gawd
    405
    Jun 21, 2011
  4. {NG}Fidel
    4,888
    Jan 17, 2005
    I enjoy my ncase temps and noise when OCed.
    Thing is basically silent, I am someone that came from the high end air cooler group and switched to water cooling, AIO or otherwise.
  5. cybrnook
    cybrnook Gawd
    877
    Jan 14, 2013
    Get with me before you buy the board, I have one thats bnib that I could sell you.
    Keep in mind, this board has a narrow ILM mounting system, so you need to be careful about your cooling. Noctua sells narrow ILM coolers, if you want to go air.
    I see you are looking at a Xeon, I have a 2620 v3 I could sell you ( as well as ECC and non ECC ram kits)......
    If you want water cooling, auqacomputer sells narrow ilm adapter plates for their water blocks (custom). As well, the board comes with an adapter, but seems to have limited support. Here is a good thread to follow:
    http://www.overclock.net/t/1592811/lga-2011-v3-narrow-ilm-and-all-in-one-liquid-cooler-compatibility
  6. ///AMG
    ///AMG 2[H]4U
    2,640
    Sep 19, 2012
    PM'd you about the board, not interested in your 2620, looking at getting a CPU with 12+ cores.
  7. cybrnook
    cybrnook Gawd
    877
    Jan 14, 2013
  8. ///AMG
    ///AMG 2[H]4U
    2,640
    Sep 19, 2012
    Looks like I will be building this either this weekend or beginning of next week for the most part, only thing that wont come in time is the case which I might just get something else.
  9. cybrnook
    cybrnook Gawd
    877
    Jan 14, 2013
    YH(another)PM - M.2
  10. ///AMG
    ///AMG 2[H]4U
    2,640
    Sep 19, 2012
    Some one recommend me 2 slot GTX 1070s that are reference length. Also what is the best manufacturer these days?. My Gigabyte ended up being too thick...
  11. cybrnook
    cybrnook Gawd
    877
    Jan 14, 2013
    Too think or too long? (No jokes :) )
    They have mini itx 1070 and 1080's out.
    Reference designs are all the same I believe, boards made by Nvidia. Only difference is the sticker.
  12. ///AMG
    ///AMG 2[H]4U
    2,640
    Sep 19, 2012
    I have two cases at the moment to see which I like better the Thermaltake Supressor F1 and the Ncase M1. Its too thick for the F1 and literally just a mm or two too long. It fits the M1 but just barely so I am just going to swap it for something else to make it easier.
    For those who are wondering I have the Gigabyte GTX 1070 Extreme Gaming 8G, really regret getting this card now lol.
    Also didnt realize they had itx 1070/80s
  13. Kardonxt
    Kardonxt 2[H]4U
    2,374
    Apr 13, 2009
    From the benchmarks I have seen the ITX versions are a bit slower if it makes you feel any better. Their boost is less aggressive to keep temps down.
  14. cybrnook
    cybrnook Gawd
    877
    Jan 14, 2013
    What resolution are you going to be gaming at?
  15. ///AMG
    ///AMG 2[H]4U
    2,640
    Sep 19, 2012
    4K but I don't really play graphic intensive games much. Also not really too picky about ultra settings.
  16. cybrnook
    cybrnook Gawd
    877
    Jan 14, 2013
    Could likely get away with a 1060 even.... Less heat, less power draw.
