X570 AORUS ELITE
drpcphil
whats the deal with the e and f versions of Bios please? Are these final release versions? Are the in Beta? Id like to keep my brd up to date is all thanks
mnewxcv
Most board makers say don't upgrade bios if you aren't having an issue or upgrading to support a new cpu. Read the notes for each bios.
drpcphil
Well id like to update\upgrade for my Future amd 5800x and 6800 Card
F31h
9‎.57 MB
2‎020/11/16
  1. Add "AMD Smart Access Memory" function
F31e
9‎.57 MB
2‎020/10/29
  1. Update AMD AGESA ComboV2 1.1.0.0 C for performance optimized on Ryzen 5000 series processors
SO i was wondering if the E and F are beta or final releases of the Bios?
mnewxcv
I see what you are saying. I don't think either are beta though, or they would be labeled as such. If you want to be cautious just do F30 which supports ryzen 5000, and wait a couple of weeks for the next release.
Nobu
Check the gigabyte forums. They may have a more detailed description from one of the GB staff somewhere.
